Tie rod end broke, truck left me stranded for the first time.
Old Mar 13, 2006 | 07:37 PM
  #31
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
Originally Posted by lees99f150
i got it from TSC. its a needle with a grease fitting on one end so you plug it in to your grease gun.
http://www.mytscstore.com/detail.asp...productID=2557
Huh, never seen one, guess I'll run by TSC tomarrow. Sure would save on repairs.
Old Mar 14, 2006 | 03:54 AM
  #32
Kool Aid's Avatar
Be sure you are using the same, or very similar grease, or you will create a much bigger problem.
Never mix grease types.
Old Mar 14, 2006 | 05:37 PM
  #33
PSS-Mag's Avatar
wonder what they use from the factory?
Old Mar 14, 2006 | 08:07 PM
  #34
lees99f150's Avatar
the wrong grease is better than no grease
Old Mar 14, 2006 | 09:43 PM
  #35
PSS-Mag's Avatar
That's kind of my thoughts, honestly I probably never buy the same tube twice anyway. More honest, I really can't tell you whats in the gun now.
Old Mar 15, 2006 | 12:00 PM
  #36
Zaairman's Avatar
I always thought that the grease that went in the guns was just the same
Old Mar 15, 2006 | 05:50 PM
  #37
PSS-Mag's Avatar
There is a wide variety. Lithium, silicon based, and I dont know what all. Each claims to be superior to the others. I figure as long as there is a cushion between the moving parts.. Then the parts wont wear as fast.
Old Mar 16, 2006 | 05:05 AM
  #38
Kool Aid's Avatar
If you mix two incompatible greases (?), you end up with a watery non-grease mess.
Much worse than a "never been greased" joint.
Squirt some in there, then check it in about a week. If the grease comes running out of the boot, then you used the wrong type.
