Coffee flat . . . . dang it.
Old Feb 9, 2006 | 09:59 AM
kobiashi's Avatar
For the past 3 days my coffee has tasted flat.
No matter how many scoops i put in, no matter which kind of coffee -
FLAT.
Tastes like coffee flavored water.
Coffee maker working?
Check.
Water filter changed recently?
Check.
Other foods and beverages still have full flavor?
Check.
I don't know what's up. I was up at 6 AM today!!!! I almost never get up that early!!!! It's at times like this I NEED STRONG COFFEE !!!!!!
And what do I get?
Meh.
OK. I'm done.
We now return you to the forums, already in progress.
I could use a quintuple espresso right now:
Old Feb 9, 2006 | 10:02 AM
Scrub your tounge with your toothbrush, then rinse with listerine. About 2 hours later, you should be back to normal.
Old Feb 9, 2006 | 10:06 AM
kobiashi's Avatar
I do that twice every day.
Floss too.
(Not that you needed to know this)
So that's not the problem.
Old Feb 9, 2006 | 10:13 AM
Ok, have you checked your water?
Old Feb 9, 2006 | 10:21 AM
vader716's Avatar
I think you have built up a tolerance to coffee
The way I see it you have two options.
1. Chew coffee grinds.
2. take a break from coffee for a few weeks to let your taste buds reawaken and ache for a taste of coffee...
Assuming #2 is just a pipe dream...flossing is important...them grinds really get stuck between the teeth.
Coffee on
Old Feb 9, 2006 | 10:26 AM
closer9's Avatar
Maybe you shouldn't floss the tounge so aggresively...
hope no one takes that out of context
PONY_DRIVER's Avatar
Get a fresh can of coffee?
Old Feb 9, 2006 | 10:38 AM
vader716's Avatar
just an FYI:
