Does this sentance make sense?
Old Jan 17, 2006 | 11:33 PM
Budha05STX's Avatar
Run-on Sentences and Comma Splices
A run-on sentence results when two independent clauses are joined without a conjunction or without punctuation. A comma splice results when two independent clauses are mistakely connected with a comma instead of being separated into two sentences or joined with a conjunction or a semicolon. Run-on sentences and comma splices should be avoided for the same reasons that sentence fragments should be avoided: they are hard to read, they confuse the reader, they suggest that you are careless, and they indicate that you do not know what a sentence is.
Revising Run-on Sentences and Comma Splices
There are several ways to revise run-on sentences and comma splices: by using a period between the independent clauses, by inserting a semicolon between the independent clauses, by placing a comma and a coordinating conjunction between the independent clauses, or by using a subordinating word to make an independent clause a dependent clause. For example:
· Use a comma and a coordinating conjunction (and, but, yet, nor, for, or, so) between independent clauses.
Example: The physicist Marie Curie discovered radium, and she won two Nobel Prizes.
· Use a period or a semicolon between the independent clauses.
Example: The physicist Marie Curie discovered radium. She won two Nobel Prizes.
The physicist Marie Curie discovered radium; she won two Nobel Prizes.
· Use a semicolon plus a conjunctive adverb (also, furthermore, however, nevertheless, similarly, therefore, next, finally, indeed, certainly) or a transitional expression (as a result, in fact, at the same time, in conclusion) between the independent clauses.
Example: Marie Curie and her husband, Pierre, worked together at first; however, he died at age 47.
· Revise one independent clause into a dependent clause.
Example: Radium, which can cause cancer, is also used to cure cancer.
Old Jan 17, 2006 | 11:35 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
I took another look at it just for your benefit and I discovered something.
If you say it fast enough, it makes sense.
Old Jan 17, 2006 | 11:37 PM
vader716's Avatar
So see...ya'll are just slow readers....
VINDICATION
Old Jan 18, 2006 | 02:34 AM
wild-mtn-rose's Avatar
I got the general idea of what you were trying to get across. It would probably help if I had some idea what you were talking about!! In general, it made sense but was a little long and could probably be broken into two sentences to make it more user friendly.
I know, I know; I'm just a woman and I need to get back in the kitchen. . .bite me Vader!
Old Jan 18, 2006 | 05:44 AM
98Lariet4x4's Avatar
Vadar,
Nothing wrong grammatically with the sentence. It may be that there are technical terms involved that make it confusing, but technically, it makes sense to me. I had no prob reading or understanding.
BTW, I realize this may be a little late, but at least this swings the tide back in your favor.
Old Jan 18, 2006 | 07:16 AM
Raoul's Avatar
25 Year Member
"Certain applications of the Intrusion Detection System may be redundant as the firewall in place may already possess these capabilities."
(Lucky for you, I stayed at a Holiday Inn Express last night)
Old Jan 18, 2006 | 07:39 AM
serotta's Avatar
I couldn't get past the title:
NO!
It should read: Does this sentence make sense?
Old Jan 18, 2006 | 07:54 AM
Raoul's Avatar
25 Year Member
I was working on my taxes last night.
Somehow, it didn't seem right to comment on indiscretions with the thread title while I was entering Vet bills on Line 1 of my Schedule A.
Old Jan 18, 2006 | 07:58 AM
serotta's Avatar
Isn't that why you named them all "Billy"?
Old Jan 18, 2006 | 08:49 AM
mountaineer02v8's Avatar
You know Vader, if you wanted a bad sentace to start with, you could have had me write it for ya!
Old Jan 18, 2006 | 09:04 AM
wstahlm80's Avatar
Vader:
It does not make senese to me.....try this one......
"The traditional Intrusion Detection System may find that the system it was developed to augment and assist with network security and the firewall, may in fact incorporate the IDS technology into its own functionality, thus eliminating the need for a separate intrusion detection system. "
Old Jan 18, 2006 | 09:11 AM
vader716's Avatar
Originally Posted by wstahlm80
Vader:
Well I'm giving up on it and I appreciate the assisst....
Bill your sentance changes the meaning. The addition of the word "and" places net security and the fw together when I was trying to say the firewall is what is being augmented...
oh well....I rewrote it for the masses...
Old Jan 18, 2006 | 09:14 AM
vader716's Avatar
NO!
ok fine......I's just the dumbist
wstahlm80's Avatar
Well.....it just goes to show my ignorance on the subject......
Old Jan 18, 2006 | 09:21 AM
Net Wurker's Avatar
Vader, that is one super sophisticated IDS system if it is has "human-like" feelings about it's own mortality.
