Stripped Oil Plug -- Opinions and Help Needed
Old Jan 17, 2006 | 03:12 AM
  #31
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Originally Posted by Kool Aid
Never had one leak one drop.
I wouldn't use one on a 4X4 that I take off road. It would be too easy for a tree branch or something else laying on the ground to open it up.
But for highway use, they rock.
Oil changes are sooooo easy. I don't need tools, or a jack.
I have one on my truck and all i did was to attach a zip tie (for off roading) and the valve cannot open. Then when changing the oil i ship it drain it and re-zip it. hope it helps...
Old Apr 4, 2006 | 02:56 PM
  #32
strone88's Avatar
Question stripped oil plug
Well, I hate to admit this but in the 91K miles I have on my 99 5.4 150 that I have been changing my oil for some reason last night I forgot which way my oil plug is turned to get it off and ended up stripping the bleepin thing. I use a creeper and come in the from grill side of the truck to change and I thought that pulling towards me which would turn the plug clockwise would loosen?? the plug. I tried the vise grips and hammer last night but with no success. Isnt the saying righty tighty lefty loosey, or did I mess that up as well. I guess maybe I need to here pull or push on this thing, either way I am mad and confused and need someone to get this figured out. I am picking my new plug tonight. Also is this metric or standard? For some reason 14mm is ringing a bell. Should I buy a socket for that or something else?
Thanks in advance FORD brothers for something pretty silly but hey we all screw up sometimes
Old Apr 4, 2006 | 03:25 PM
  #33
When you scoot under to take out the plug, take a ratchet with you. Make sure it is in "remove" position and try it in your fingers. That will tell you which way to turn thr plug. Always worked for me.
Old Apr 4, 2006 | 04:26 PM
  #34
northernnorm's Avatar
Like you said, "righty-tighty, lefty-loosey". But earlier you said "clockwise would loosen." You can't have it BOTH ways. It seems that you look at things a bit differently. When I look at something, if I turn it clockwise, I'm turning it to the right, unless I'm 'behind' the object (in this case I would be inside the oil pan), in which case, I WILL be turning it to the left.
So. Clockwise is right is tight. Anticlockwise is left is loose.
Hope this clears up your dilema.
Last edited by northernnorm; Apr 4, 2006 at 04:28 PM. Reason: Just had to clarify the behind thing
Old Apr 4, 2006 | 04:35 PM
  #35
Net Wurker's Avatar
You have to think of it "as the nut turns" and not "as the wrench swings"....
Old Apr 4, 2006 | 04:37 PM
  #36
tbizzle's Avatar
I suggest getting a new F1Fity. That should take care of your stripped oil plug.
Old Apr 4, 2006 | 04:47 PM
  #37
Net Wurker's Avatar
He would need to be able to drive it to the dealer in order to trade it in. With no oil in the pan....kinda tough to do.
Maybe there are some pills he could buy, and throw them in the crankcase....
Old Apr 4, 2006 | 05:16 PM
  #38
tbizzle's Avatar
Quite humorous!
Old Apr 4, 2006 | 05:19 PM
  #39
I would be afraid that thing would explode before I got there. Of course you may have come up with a new use for the pills, it may stop oil consumption.
Old May 28, 2006 | 08:22 PM
  #40
Kool Aid's Avatar
Ok, so it's been long enough for at least a few oil changes for those that were going to buy the valve.
Any comments?
I just changed my oil today, and it only took about 10 minutes.
I really like this valve.
Old May 29, 2006 | 12:14 AM
  #41
Quintin's Avatar
Like the half *** I am, I haven't bought a Fumoto valve yet. I'm in a unique position to where I've got access to a lift and lots of tools, so I don't really have a need to get that thingy, but it would be nice especially if I decided to start doing my oil changes at home.
Old May 29, 2006 | 01:51 AM
  #42
RobNY's Avatar
Hey RP you could try using a helicoil. I had the same problem in my old 86 Bronco when Jiffy Lube stripped out my oil pan plug ...You can google helicoil or check out this link for a general idea.
http://images.google.com/imgres?imgu...lr%3D%26sa%3DN
Old May 29, 2006 | 01:39 PM
  #43
Rockpick's Avatar
Moderator &
I'm three or four in with a Fumoto on both my truck and the wifey's Explorer... I LOVE THIS THING... simplicity isn't the word.
Thanks again for the help and suggestions.
Old Jul 2, 2006 | 07:45 PM
  #44
ChappyFX4's Avatar
I had a Fumoto on my last vehicle and oil changes were a snap. One think it was recommended to do was use a brass crush washer with the fumoto valve. Supposedly the blue fiber washers dont do a great job at preventing leaks. Anyone have any issues with the blue fiber washer?
