Anyone use Edelbrock fuel line/filter kits? (carb)
Just curious if anyone has used an Edelbrock fuel line kit, #'s 8131, 8134 or even the 8126? If so, what do you have running from the fuel pump up to the filter? I've always used hard lines up to within a few inches of the filter then rubber lines up to the carb.
Well, I was thinking these look much nicer, and probably seal a little better than hose clamps. I was thinking about getting the 8126 which is just their fancy fuel line to the carb with a hose barb to connect the filter, using a 8873 filter.
I don't really want to go the expense of getting braided flex lines to run from the pump to the filter...
So, just curious what some of you guys have done. I'm not concerned with being or looking stock BTW...
thanks...
thanks...
