Ethernet Cable help
Old Feb 25, 2005 | 07:10 PM
zacky's Avatar
Ethernet Cable help
Dumb question is there a way to tell difference between straight-through and crossover cable just by looks ?
to add to this question i have a cable thats installed in the house now can't remember if its crossover or straight through anyways it runs from point A to point B i'm changing internet supplier from satelite to wireless if this ethernet cable is the wrong one can the installer just cut off the end and change it from straight-through to a crossover ?
Old Feb 25, 2005 | 07:29 PM
vader716's Avatar
Take for instance;
Straight will look like this pattern on both ends (colors can change but they always match on both ends)
White Orange
Orange
White Green
Blue
White Blue
Green
White Brown
Brown
A cross over will have the above on one end and
White green
Green
White orange
Blue
White Blue
orange
White Brown
Brown
Cables 1 & 3 and 2& 6 are swapped.
Old Feb 25, 2005 | 08:35 PM
Johngs's Avatar
Easy way to tell is the method vader listed, although there are two different types of arrangements for patch cables (straight-through cables).
Also, if you had the cable connected directly to two computers (no hubs/switches/routers involved) then it is probably a crossover cable. If your cable was going from a modem to the computer, its probably a patch cable.
If necessary, yes the installer can cut off the end and re-wire it.
Old Feb 25, 2005 | 09:19 PM
zacky's Avatar
Great if they can just rework the cable that saves me some work its plenty long at each end its installed in the wall and underfloor but goes exactly where i need it Can't wit to get rid of this Satelite internet damn software / provider is a pain in the ***
Old Feb 25, 2005 | 09:24 PM
vader716's Avatar
If the cable worked for one provider it should work for another.
Cross overs are generally used to connect hubs and like Johngs said, two computers directly.
You should be fine.
Changing a cable end is a 5 minute job.....nothing to it.
Old Feb 25, 2005 | 11:21 PM
RandallT's Avatar
Zacky, Vader is 100% correct in the pattern of the pairs of the cable. If for some reason you did what he said and put the colors in order they would go from left to right, that's just the way I look at them when I terminate them, but it should work as is right now......just my 2 cents.
White Orange
Orange
White Green
Blue
White Blue
Green
White Brown
Brown
Old Feb 26, 2005 | 07:01 AM
Faster150's Avatar
You should be fine.
takes me a minute and a few seconds working for damn school i was only one who wasnt color blind so just about every drop i was the one punching them down or terminating the ends. lol it was easy but hurts ur fingers from straightening the wires
Old Feb 26, 2005 | 09:36 AM
vader716's Avatar
Faster,
I couldn't agree more.
After a few drops....my your fingers start to ache.
Stripping, untwisting, straightening, clipping...argghhh I'll stop now my figures are starting to cramp.
Old Feb 26, 2005 | 01:15 PM
Faster150's Avatar
yeh its bother some when ur good at something so thats what they make u do... gets boring lol but i can damn near do it in my sleep. if it werent for the colors to look for...
