Ford Easter Eggs and other neat tricks
I read some tips on hidden features of the 6-cd audiophile head unit.
The one where you can press 2 buttons (forgot already) and put the unit in "Ship Mode".
If you ever buy or sell on eBay, this would be very helpful.
HUH, I wonder what it actaully does?
Sounds interesting.
Have to send instruction on how to get it out of Ship Mode.
Then your customer would think that you were the smartest person ever and trust you again later.
Sounds interesting.
Here's a trick for ya Matt. If you hold down your brake, and press the gas, your truck will put on a smoke show for ya! Or, when going around a corner, press the gas to the floor. The rear end of the truck will try to pass up the front. Usually they just end up swapping spots.
)Heres another, if you're going about 35 mph or so.. slam on the emergency brake. Your back end will spin around and you'll be heading the other direction!
Sure beats pulling in some where to trun around. LOL
I've been known to park my truck like that at school once...I make a sharp left right into my spot, and when it's wet out, that blacktop is like ICE!
And as for the noposi, that's an easy fix.....besides, you've been needing the 3.55s/3.73's.
Originally Posted by CrAz3D
Sheesh, that sure seems like alot to do to make the dinging stop. Is there a way to make it stop dinging when the door is open?... I like to clean with the radio on & don't like the door ding.
Yeah....its called an ipod.
ewww, boo, hiss!
Detroit Lockers!
If I have to replace them anyway.... pretty much the same price so might as well get the better!
Originally Posted by PSS-Mag
Posi???
ewww, boo, hiss!
Detroit Lockers!
ewww, boo, hiss!
Detroit Lockers!
. It's pretty tight, even light gas around a sharp corner from a stop will leave the inside tire chirping.
Or, just run the factory posi on what I believe to be the original rear diff fluid (103K)
Originally Posted by Corpsie
Of course the inside tire will chirp, it's got the least amount of traction.
Ratcheting, but locked. Not worried about having the inside chirp, I want both tires to burn off, plus it wont spin as long.
I know its an old thread, but I thought I'd add one to the list....
While cruising down the road press and hold the "on" button and the "coast" button on your cruise at the same time. The horn will honk.
Works on my brothers 2003 f150 and my 2003 f350.
