Survey: How many miles before problems
Old Sep 14, 2004 | 04:49 PM
zski128's Avatar
After reading posts on this board I have come to the concluesion that not everyone can be having problems with thier truck! Please post the mileage that you had before you had problems (not caused by your own doing). Or, if you have not had a problems post your current mileage. Please include your model year and type:
2001 F-150
5.4L auto
SuperCab Lariet 4x4 w/ ORP
63,000 miles and only fluid changes.
Old Sep 14, 2004 | 05:25 PM
PhillipSVT's Avatar
99 4.6 f150
auto trannly
45,000 miles
Driven hard. Fluid changes, chip & FTVB.
took it in once at 30,000 miles for rough idle, but they thought it was bad gas. Since then no problems. Other than a broken window arm in the door. Mechanically been great!
Old Sep 14, 2004 | 05:39 PM
Habibi's Avatar
2002 F150 XLT
4x4
5.4
Supercab
I factory ordered this truck and it had about 5 miles on the speedo when I took delivery.
Far too many oil changes to count and all required service.
Only failure I ever had was the drivers side power mirror switch went. Dealer replaced under warrenty.
Truck has been chipped since 800 miles as well as Gibson exhaust and AF1 intake.
I replaced the front brake pads last week and the rotors are still good, not even turned yet.
Old Sep 14, 2004 | 10:10 PM
Pickup Man's Avatar
1997 F-150 supercab 4x4 flareside lariat, 4.6 automatic.
1 tensioner pulley, 1 brake caliper, fuel filter, plugs and wires. Now, a heater hose. The plugs and wires didn't really need changed, the fuel filter was the culprit of my misfire, but they had 110,000 miles on them, so I figured they were due.
Old Sep 14, 2004 | 10:16 PM
Quintin's Avatar
'97 F250 LD, 4x2, 5.4/4R100. Went 100K-something before #3 plug blew out. Other than maintenance items and an alternator, that's the only big problem I've had with it. (Knock on wood)
My '04, I guess the biggest problem, the one that annoyed me the most was when the fuel filler latch broke. That was at 6900ish miles.
Old Sep 14, 2004 | 11:11 PM
dzervit's Avatar
04 F150 - 7k and no real problems.
99 Expy - 97k and no real problems
97 F150 - 60k no problems
All driven like it was the last day I was going to live.
Habibi - it's about $*#(@ time you used that sig...
Old Sep 14, 2004 | 11:28 PM
lees99f150's Avatar
99 5.4 4x4 tow offroad xlt f150
problems started about 30 k miles the last 10k have beem ok. its got 65k on it now.
Old Sep 14, 2004 | 11:37 PM
Green_98's Avatar
70,000 miles even
brake pads, turned rotors, new serpentine belt
And a broken window last week...138 bucks gone
Only real mechanical problem ive had was when the truck had 400 miles on it, it had to have a completely new rear end due to the fact that there was no oil put in the rear end from the factory
Old Sep 15, 2004 | 04:00 AM
wild-mtn-rose's Avatar
Bought it with 8 miles now at 21,000 and no problems except that the darn thing keeps getting dirty. When are they going to invent self cleaning paint???
Truck specs in sig:
Old Sep 15, 2004 | 08:23 AM
EddyG88's Avatar
7000 miles and only a little grooving of the rotors.
Old Sep 15, 2004 | 12:39 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
99 F150
5.4L
81,000 miles
recommended maintenance plus:
IAC
front brake pads
new rubber
(oh and new tires too)
Old Sep 15, 2004 | 09:18 PM
sleddogg's Avatar
99'
Reg Cab Flareside XLT
5.4
Creepin up on 110K
Just regular service
Other wise no unexpected troubles
Brakes and rotors at 70K
20k on last tire set. Smoke = new tires.
Sled...
Old Sep 15, 2004 | 09:27 PM
Green_98's Avatar
sorry to hijack the thread i just noticed something::
sleddog, i noticed you had walkers exhaust. Do you have mufflers or Walkers Glasspacks?
Old Sep 15, 2004 | 10:20 PM
jpdadeo's Avatar
12,000 miles & everything is perfect
Old Sep 16, 2004 | 04:53 AM
Gearhead99's Avatar
01 King Ranch Screw
55K
Brakes, Tires, Amsoil, Battery, DPFE sensor
Been a very good truck !!!!
