f-150 7700?
Old Jul 7, 2003 | 11:24 PM
wolf_creek_61's Avatar
f-150 7700?
has anyone here ever heard of a F-150 7700? i saw one today the fender badges said xlt but the tailgate badge said 7700 in place of the xlt im guessing its a work truck package or something related to that because it was an 8-lug set up and had a massive rearend housing
Old Jul 7, 2003 | 11:36 PM
Up N Flames's Avatar
My truck is a 7700. It's 7 lug. Same as the old 250 LD's. Heavy duty frame, shocks, trans, rr 10.25 LS with 4.10. Plus other stuff like radiator cooler and larger brakes.
Old Jul 8, 2003 | 01:43 AM
2000f150man's Avatar
I have a 2000 f-150 7700 package which has:
- 2625 lbs Maximum Payload
- 7700 lbs GVWR
- 5.4L EFI V8 Engine
- Larger Brakes
- 16" 7-Lug Styled Steel Wheels
- LT245/75Rx16D OWL All-Terrain Tires
- Heavy-Duty Frame
- Heavy-Duty Shock Absorbers and Springs
- Heavy-Duty 72-Amp Hr Battery
- Radiator Upgrade
- Snow Plow Capability (4X4)
- Auxiliary Oil Cooler (14-Plate)
- 3.73 Axle Ratio; Optional 3.73 Limited Slip
Old Jul 8, 2003 | 07:51 AM
Rockpick's Avatar
Moderator &
I've seen the truck you're talking about... My understanding was just like the other guys mentioned...
7 Lug and kind of a super duty F-150.
Old Jul 8, 2003 | 08:48 AM
yesterday is the first one i have ever seen kinda suprising seeng as how i work at a ford dealorship
Old Jul 8, 2003 | 11:08 PM
bloomquist's Avatar
What do you do at the dealership Wolf Creek?
Old Jul 8, 2003 | 11:11 PM
Rockpick's Avatar
Moderator &
You certainly see a bunch more of them than I ever would... I've only seen one and it was in South Bend, Indiana (well, actually Mishawaka, In (right next door to Notre Dame/South Bend)).
Old Jul 8, 2003 | 11:49 PM
mostly detain cars but i do some brake work oil changes minor repair and i do parts runs and vehicle pickups from other dealors
Old Jul 9, 2003 | 12:13 AM
bloomquist's Avatar
See Italicized above- Did you mean soemthing else?
Old Jul 9, 2003 | 12:54 AM
detail cars my fault completly
Old Jul 9, 2003 | 11:34 AM
2stroked's Avatar
Just to confuse matters a little bit more, the truck now sold as an F-150 7700 package was sold in 1997-1998 as an F-250 - but not a Super Duty. It's essentially a light duty F-250 or heavy duty F-150 depending on how you want to look at it. There used to be two visually identical F-250's in the pre-1997 body style with one being lighter duty. Some folks who didn't know the difference found out that the lighter duty version made a crummy plow truck due to the lighter duty components. So, confused even more?
