what wieghs more?
I have heard that the Flareside is lighter because the bed is made out of a composite material that is lighter than the conventional material used on the fleetside. Not sure what kind of material that is used, though. Anybody else know anything about this?
It would be difficult to get two trucks outfitted exactly the same, same amount of gas etc... especially when the numbers are as close as they are.
Here is the curb weight from Ford on both vehicles for '03
(this assumes a V6, stick, I guess)
FLareside - 4044
Styleside - 4032
I remember reading that the Flareside was slightly more back in '97 also so, I assume it was true for all the years of this Style.
It so close, under and over inflated tires could change the result.
FLareside - 4044
Styleside - 4032
I had mine on a set of scales and its weight was 48??. It's a 98 Flairside, 4.6/4r70w, supercab XLT, tow pac, bedliner.
Funny thing though, I had my 95 Dakota extended cab on the same scale and its weight was 45??. Not much difference for a smaller truck. It did however have the 318 and tow pac. If the scale is close to right the dakota was heavy for its size.
