shocks for '06
Shock Recommendations IMHO:
1) Koni- Excellent for racing applications- overpriced for street applications
2) Tokico, QA1 & Bilstein- A very good shock for street/strip applications. If you are running very stiff tires on the street, these provide the extra give that you need for both comfort & stability
3) KYB- A very good shock for street/strip applications. If you are running a softer tires on the street, these provide the extra stiffness that you need for both comfort & stability. The Exel-G’s (formerly GR-2) are the equivalent to the Edelbrock IAS automatic adjusting units. Overall, stiffness between the Gas-a-just and the GR2’s are the same, the difference is the GR-2's valving which stiffens things up from a oem setting to that of the Gas-a-just units.. Best shock for the $/best price typically found at Performance Suspension Technologies (PST) and typically about 1/3 less than Bilstein.
4) Gabriel- A very nice good quality HD OEM replacement type unit.
