Rusty oil pan in a Powerstroke???
Has anybody heard of the Powerstroke oil pans being prone to rust? My co-worker has a 2000 F350 one ton with a 12 foot cube and just recently took it in for a routine oil change. This truck has about 100k on it and is religiously maintained. After the oil change, she found a puddle on the warehouse floor and assumed that they buggered up on the filter installation and took it back. They told her the Ford pans were prone to rust because of poor paint applications and it is now perforated. They want a thousand bucks to pull the motor and put on a new pan. I said that sounds very fishy and she should get a second opinion. I do all the maintenance on my own work van and probably should've offered to look at it for her, but, I don't really want that responsibility. However, I still think she's quite possibly being duped, but I just wanted to see if anyone else has had this "problem"
Nope that sounds about right. The 7.3L in the last few years, specifically the 99+ SD engines, did have problems with pain applications. It is not uncommon at all to see them rust out, espcially in areas where they use alot of road salt. If it has rusted through the engine does have to come out to change it and the quote of $1000 actually seems very fair compared to many other quotes I've heard for this type of repair. I guess she has an expensive repair coming up here real quick.
If the pan already has a leak the "putty" type repairs do not last long at all. All of the PSD engines have an oil pan perforation issue, both of mine (96,00) have had the pans replaced. She will want to get a "coated" pan from IH to replace the factory painted one. They do last longer, or have her new pan coated with Rhino Liner or something similar. The paint on the new pans isn't any better then the stock painted pans.
Egads boys!!! Yeah, the putty solution? didn't even make it out of the shop, so she bit the bullet and got the local Ford dealer to pull the motor and install a new pan she purchased from NAPA, BUT, and this is a big BUT, they used silicone to make a gasket, which I'm not sure, but I thought it would have to be neoprene or cork on an oil pan. Anyways, guess what happened after it was all put back together, yup, still leaks. Her truck has already been down for a week and will probably be out of commission for at least another couple of days. Before she goes through this again, can someone tell me what the proper gasket material is for a PS oilpan. The Ford dealer figures their mechanic just used the wrong kind of silicone. This is just assinine, you'd think a dealer would know, without question.
