F-250 / Super Duty / Diesel
Attn: Spaceace.....K&N question!
Old Jan 4, 2000 | 09:21 PM
Truckin4's Avatar
Post Attn: Spaceace.....K&N question!
Spaceace,
I saw on another thread you posted a picture of (assuming it's yours) a V-8 gas motor with the K&N air filter. I noticed your K&N is exposed, and does not have the oval air assembly surrounding the filter. I purchased the K&N filter for my V-10, which is the exact same part number. When I installed it I just replaced the stock filter with the K&N, and put the air box assembly back together. Do the V-8s come without this assembley or did you remove it yourself? If you removed it, may I ask why, and what are the advantages/disadvantages of doing it this way? I want to do whatever will give the the most out of the K&N but don't want to remove the oval air box assembly if it will do more harm than good. Thanks.
2000 F-250 SD XLT CC LB AT 3:73LS 6.8L
My 2000 SuperDuty
Old Jan 5, 2000 | 02:35 AM
V10 man's Avatar
Post
I decided to cut the 2 some odd inch snorkle off the end of the housing and inlarged it to 4" using flexable aluminum ducting. It follows the stock route to the front of the grill to pick up cooler air. (Banks uses a mod like this as part of their Stinger/Power Pac kits) There were no noticable gains to be had. Unless there is some really noticable gains to be had, I wouldn't mess with things.
Old Jan 5, 2000 | 05:50 AM
spaceace's Avatar
Post
I concur. No noticeable gains.
I did basically the mod listed here, http://216.167.31.120/tech/airbox.html
except with custom aluminum mount. Not having the box over it cant hurt.
1999 F250 SD CC, LWB, 5.4L, Auto, 3.73, 4x4, Power TT mirrors w/ marker lights, White, Full Tint, PendaPro SR, Flowmaster Delta 40 series, K&N filtercharger, Superchip (Airbox removed for a second try, maybe in the winter it will be advantagous?) Lund Elite soft tonneau
www.angelfire.com/pa3/spaceace/index.html
