F-250 / Super Duty / Diesel
29 Gallons?
Old Nov 10, 1999 | 02:00 AM
percyad's Avatar
Question 29 Gallons?
The new 2000 F250, Super Duty, Crew-cab, 6 1/2' bed I now own comes with a 29 gallon fuel tank. Considering the monster is rather thursty and there is plenty of space under the frame, why such a small fuel tank?
Anyhow, if you have a suggestion where to find a replacement fuel tank that is larger (45 gallons?), I sure would appreciate it. I have considered "auxilary" fuel tanks, but why take up useful bed space when there is so much room underneath?
Thanks,
Alan
Old Nov 10, 1999 | 11:17 AM
J-C's Avatar
J-C
Thumbs up
The Long Beb comes with a 38 gallon tank.
Old Nov 10, 1999 | 04:42 PM
fast46triton's Avatar
Post
Get the longbed. If you want, get some aftermarket dual side tanks.
Old Nov 10, 1999 | 06:49 PM
jaxon's Avatar
Smile
There are two "replacement" (not auxiliary) tank options that I'm aware of for the 29-gal tanks that come on the F250/350s with crewcab and short wheel base.
Aero Enterprise, Inc. www.aerotanks.com
Transfer Flow, Inc. www.transferflow.com
Both are 50-gal tanks that simply replace your existing tank. I'm not absolutely sure, but I don't think either impacts your spare tire mount.
Aero's tanks have been available for some time. The info I've seen in the forums at ford-diesel.com and edmunds.com indicate they hang down lower than the stock models; reducing vehicle clearance beneath the tanks.
Transfer Flow's tank should be available in about 3 weeks (based on a phone conversation I had with them yesterday). They will initialy debut a diesel version, followed soon after by a gasoline version (They've had more demand for the diesel version).
The approximate cost for both brands is $670. Both manufacturers will install them (if you happen to be in California). Flow Transfer also has a network of installers around the country that are approved to install their tanks.
[This message has been edited by jaxon (edited 11-10-1999).]
Old Nov 15, 1999 | 05:24 AM
V10 man's Avatar
Post
Hi Guys..
If you look, there is lots of room in front of the tank. I think Ford didn't make the tank longer because it would be next to the cat. You'd think they could shield it somewhat and offer a bigger tank. I wonder if there is a way to fit the 44 gallon Excursion tank under there? LOL
Old Nov 20, 1999 | 02:38 AM
IKE's Avatar
IKE
Talking
When I told my friend it only held 29 gallons, he suggested mounting a 55 gallon drum in the bed, drill a hole through the floor, and have the line drain into the stock fuel tank.
I guess that WOULD increase fuel capacity, but I don't THINK I will be trying that idea!
<A HREF="http://www.inlink.com/~usguys2/f250.html" TARGET=_blank>IKE
2000 F-250 SD CC 4x4</A>
[This message has been edited by IKE (edited 11-20-1999).]
