Well it has been a short minute and I have changed the system up a bit. Had a new box put in and loved it but ended up wanting more. Here was a photo of the newish box with the two Sundown SA 12's. The craftmanship was awesome, and the Diamond Plate CNC work was a first I think.
I had them inverted as I liked the look, but they are now mounted in the traditional way as it is all being sold.
You can see both of the SCV2000D's in the above photo as well as one of the xp3000 which I now have two of as I will be using both amps. Had both in, but only one hooked up for the 2x12's setup.
Then I got attacked by the audio bug in a big way...........
Now I have a new box on the way, built solid, tuned to 28hz and to get low. Going to be pushing two Sundown 15xrev.2, two Sundown SVC2000D, one XS D3100 under the hood, and two XS XP3000 in the rear. Also on the way are new Sundown components both for the front and rear, and a Sundown SAX200.4
Below is the new box, port painted silver, extra internal bracing, and will be sprayed with bedliner and as you can see the box sits on top of a compartment with sliding trays that the amps will mount on.
And the subs. They are rated at 1500 watts rms each, and as you can see are huge. Weigh in at 79lbs each.
