1999 EB Expedition suspension problems
My truck has seemed to has completely fallen. the ford dealer told me that the computer chip for the left side is no longer good. But now the whole truck has fallen. is it a good idea to install a conversion kit. or repair the air suspension. The compressor was constantly on before it stopped working.
Mine is still working,Your compressor went out due to constant running,Most likely due to a air leak,The Most common part to fail on the air suspension is the small union (Near the brake Master Cylinder) Part is only like $10 from the dealer,You can buy a compressor from Arnott (Mentioned above) they are good folks & will help you with troubleshooting the Air Suspension System or you can convert it But don't expect it to ride the same after it is converted to Coil Spring Suspension.
