2003 EB 5.4 troubles, troubles, troubles.
Hello all. I did search before posting this.
The Wifes 2003 5.4 EB has on the instrument cluster "low oil/high temp"
Oil level is fine oil pressure is fine, whats the cause and fix?
Does the oil pressure sending unit activate this light? The guage says OP is fine right above the middle. Does this one sensor send the signal to both?
I also heard the instrument clusters can go bad and cause this?
I also have a DEAD temp guage on the cluster, works for the first 5 seconds of running then drops dead. I scanned it with the Solus and got the cyinder head temp. sensor come up.
Also all the sudden the ac compressor will not kick on, NO leaks, just recharges in May. This ALL happened when driving hom in the Hurricane hitting MONSTER puddles like ones I never hit before in my life. The coil packs are missing even worse now but I have a new set on the way. Is there a relay for the compressor? The #11 fuse is fine and when I jump the high pressure switch I get nothing?
Thanks a Million in advance.
