Expedition / Navigator
lowering a 2000 expy
Old Apr 25, 2001 | 07:19 PM
localtgk's Avatar
Question lowering a 2000 expy
I know there are alot of companys with lowering kits.does any body have any sugestions 2inch all the way around??? beltech,eibach,djm,and the proper way to bring it down, springs,drop spidles????
thanks tony
Old Apr 28, 2001 | 09:23 AM
KSinLA's Avatar
Post
Depends on what you have. 4X2, 4X4, air suspension, etc.
I have 4X2 with air suspension and lowered the front with Eibach 1 1/2" lowering springs. Didn't have to do anything to the rear except adjust the air suspension sensor so it sits lower. I also installed Lightning wheels and 285/60/18 Michelin Pilots. Overall effect was the wheel wells are full of tire and lowering improved lateral handling quite a bit. The Michelins also improved the ride, traction, etc.
I went with the Eibach because they offer the best ride. Smooth until pushed. Progressive tension. You'll have to install cmber kits to realign the Exp. I purchased the springs and camber kits from Tire Rack.
Old May 1, 2001 | 12:07 AM
localtgk's Avatar
Smile
thanks for replying to my message
I do have a 2wd expy im starting to lean towards installing the belltech kit
i also put on 285/60/18s but with niche rims
and yokohama tires feels great but i can use better suspension do you have any horror stories about belltech??? if you have anymore suggestions please post them..
thanks again tony
Old May 2, 2001 | 08:55 AM
EnzoWho's Avatar
Post
KSinLA,
How much did you drop the back?
I too have the rear LLS on my 98 X. I was wondering when you were under there, just how much adjustment there is for the rear? Were you able to drop the back 1 1/2" or is the front lower than the back? Do you have any pics?
Thanks,
James
Old May 4, 2001 | 07:16 PM
KSinLA's Avatar
Post
I lowered the back about 2" to bring it about level with the front at rest. I was surprised how much you can adjust the rear height. I had to readjust it a couple of times to get it right. Fortunately, it's an easy task.
I don't have any pictures. Hate to say it but I don't know how. I'd attempt to do it if someone provided me with easy to understand step by step instructions.
Old May 5, 2001 | 02:29 AM
Otis01's Avatar
Red face
Someone told me that you can adjust the torsion bars on expdition's to raise and or lower the front-end. Is this true and how is it done?
TIA
