Expedition / Navigator
97 expedition fog lights
Old Dec 18, 2008 | 03:46 PM
92F150S/C's Avatar
My 97 doesnt have fog lights installed, but while under it, I saw that there looks to be already wired for the lights. Is this correct and is all that I have to do is get the brackets, lights, and new headlight switch.
Old Jan 2, 2009 | 06:52 PM
bigbronc's Avatar
All trucks are "pre" wired for most any accessory. Used to be a kit. All you needed to do was replace the headlight switch, and install the fog lights themselves. DONE.
Old Jan 2, 2009 | 07:19 PM
BayouSupercrew's Avatar
FWIW-I had a 2000 Expy Eddie Bauer edition, I swapped out the front bumper lower valance to the Harley style and I still have the original fog lights and mounting brackets, if you have any interest, PM to discuss.
Old Jan 5, 2009 | 12:02 PM
92F150S/C's Avatar
it must of had them, the headlight switch pulls out for the fogs. must of broke them and put the cutouts in replace of them
Old Jan 28, 2009 | 09:24 PM
98Expedition10's Avatar
You might have the circuitry at the Head Lamp Switch, but you might need to add the Bosch 12V-30Amp SPST Relay in the Engine Compartment Relay Cabinet. There is a companion 20Amp Fuse in that same compartment.
Old Sep 19, 2011 | 04:22 PM
96max2fast's Avatar
I know this is old but I wanted to know if this also applies to a 97 XLT Expedition... My fogs stopped working a few days after I installed an HID kit...
Old Oct 6, 2011 | 04:27 PM
96max2fast's Avatar
Help please!!!
Which relay powers the fog lights on my 97 expedition... Fuses are fine... it's not in the Manual...
Thanks,
Old Oct 7, 2011 | 11:36 AM
oblivion's Avatar
I am pretty sure it either shares the relay with the DRL or is the one directly beside it.
Old Oct 7, 2011 | 12:01 PM
96max2fast's Avatar
Which is the DRL one... ? I ask because I dont have DRL on my 97 XLT
Old Oct 7, 2011 | 12:52 PM
oblivion's Avatar
Ah good point, I am in Canada where DRL is manditory. I'll go look at my 99 and get back to you.
Old Oct 7, 2011 | 02:13 PM
oblivion's Avatar
theres 2 fuses related to the fogs but both are shared #9 under the hood and #27 under the dash. I havent figured out where the relay is yet, but I am told if you headligh switch has the "pull out" feature to turn on the fogs is should already be wired up and ready to go. have you tested the wires for the fogs to see if they are live when switched on?
Old Nov 4, 2011 | 12:00 PM
96max2fast's Avatar
The bulb socket gets no power... there is power at the switch though, and the fuses are fine... It's gotta be the relay but I don't know which one it is, nor has anyone been able to tell me...
