Expedition / Navigator
Door lock questions ....
Old Mar 7, 2007 | 02:13 PM
bear685's Avatar
I have had the mysterious door lock problem for years = hit it with a few shots of WD40 and it goes away then comes back now my driver door lock does not respond to the power buttons at all - driver fob, inner door button, key pad, nothing will lock the door except manually pushing it down - did not try the key in the door. the right passenger door is unresponsive to the electronic options also.
anyone else have this ?? i am wondering whether i should have the door lock electronics changed or if some other non-invasive process is the cause such as some mysterious fuse combo.
if anyone has had this problem fixed mechanically, can you ball park the costs for repair/replacement of the door locks on the two doors ?? parts/labor ??
thanks.
Old Mar 7, 2007 | 06:02 PM
Camarothatcould's Avatar
Do you hear the acuator moving in the door? If so, the rod for the lock must have come undone. Common in cold weather since plastic wants nothing to do with it
Old Mar 12, 2007 | 02:04 PM
bear685's Avatar
sometimes ...
after i shoot it w/wd-40 it works correctly for 2-3 days to a week, then will not electronically move the locking mechanism.
Old Mar 17, 2007 | 04:01 PM
jeraa2t's Avatar
Unhappy bad actuators
my 03 had a few changed under warranty. Now again after a few years
I am getting a buzz on one occasionally, not opening..replacement is best.
fyi
