Expedition / Navigator
code 1309
Old Jun 6, 2006 | 05:10 PM
4montecarlo's Avatar
code 1309
I recently had a check engine light, i used the scan tool to check the code and it was for 1309 which the only info i could find was for a ford taurus and it had something to do with disabling the misfire detector
anybody know if this is the same a for a 98 lincoln navigator?
thanks
matt
Old Jun 18, 2006 | 11:18 PM
rhdf150's Avatar
I found this code for all Ford vehicles:
P1309 Misfire Detection Monitor not enabled
Good Luck!
Old Jun 26, 2006 | 05:26 PM
I ended up calling the dealership, they said it had to do with the camshaft position sensor and to check it first
So i tried to remove it, and it came out, but in 3 peices, so i assume that was the problem, new on in, and it has gone about 100 miles with no other service engine light
thanks
matt
