Misfire...changed plugs, now what?
Ok, check engine light came on yesterday, the truck was "bucking" and i knew i had trouble. Scanned it, and came back "misfire in #3"...so i take it into the dealer and they install 8 new plugs. (Bosch +4).....They call me up just now and tell me that there is still a slight misfire in #3. They said tommorow they are going to move the coil packs around and see if that is what may still be causing the misfire.
Sounds reasonable to me....does this sounds correct to you guys as well and is there anything else I should be aware of that may cause this misfire? Thanks. MATT
its a 5.4L BTW
its a 5.4L BTW
