Expedition / Navigator
Aftermarket receiver with Mach system?
Old Feb 16, 2005 | 12:26 AM
newyorkboy's Avatar
What is the mach system and how do you know if you have it in your truck.I know it has something to do with the radio but thats about all i know.
Old Feb 16, 2005 | 08:40 AM
coolfords's Avatar
My speaker grills have "Mach" listed on them and it has a Sub woofer in the back on the pass. side of the cargo area.
Mine is a 2000 EB Expy
Old Feb 16, 2005 | 11:03 AM
Buzzz's Avatar
I read that 98 and up had the Mach setup, where as 97 had the JBL setup.
If you have a subwoofer in the rear passenger cargo area, next to the jack you have the Mach.
FWIW, I used the Metra dash kit 77-5802. I hate that damn little pocket but thats all I could find to work. It says 77-5804 works as well, but that still has the pocket.
Old Feb 16, 2005 | 11:06 AM
Buzzz's Avatar
Did you install an aftermarket head unit? If so, what dash kit did you use?
Old Feb 16, 2005 | 01:31 PM
coolfords's Avatar
Not yet
I have posted a few questions and yours was the first thing that answered some of them.
My budget is not as big as yours.
I am thinking about an Alpine HE.
Old Feb 16, 2005 | 03:26 PM
Buzzz's Avatar
Not yet
Just get one with time correction.
http://www.crutchfield.com/S-hH0bi7B...0&I=500CDA9833
That ones on sale. Also check sounddomain.com.
Old Feb 16, 2005 | 07:31 PM
coolfords's Avatar
That is the one I am looking.
The Alpine CDA-9833
Old Feb 16, 2005 | 09:41 PM
rainman15's Avatar
Originally posted by Buzzz
Whats crutchfields product number?
This is from the e-mail they sent me. I still don't think it is right.
Item Description Ship Qty B/O Qty Price Amount
0000190104 FORD EXPLORER/RANGER... 98- MS
003FMK550 Ford Kit 1995-up, S/E 1 0 19.99 19.99
What is this time correction I keep hearing about. I don't know if my Alpine has it. Mine has a mode called BBE but I don't know if that incorperates time correction.
Old Feb 16, 2005 | 09:49 PM
rainman15's Avatar
This is the option list I found online for my cd player. It doesn't list anything about time correction. Will this mean I can't use it with the Mach system in my truck?
Old Feb 17, 2005 | 11:16 AM
Buzzz's Avatar
No you don't need it. It just makes the sound better. It posistions the sound so that the imaging is in front of you. As opposed to the stock system sounding like the sound comes from the front left speaker.
Old Feb 19, 2005 | 08:39 PM
rainman15's Avatar
Well the box finally arrived from crutchfield and when I opened it what do I find? The damn mounting adapter kit that I told the guy 3 times I already had. No wiring harness. That guy must have been on crack to screw that order up.
To make a long rant short, I called them back to tell them I had received the wrong part and they needed to send me the correct harness. The guy told me that the harness would be $49.95! F'k that. I'll just wait till spring and install my entire system with my own amps and speakers once the snow melts. What a waste of time!
Old Feb 22, 2005 | 10:07 AM
Buzzz's Avatar
Wow thats really strange. Crutchfield has killer customer service. I am sure they will straighten it out.
Have you pulled the oem receiver out and looked at the connections? Im curious if they are the same is mine. Also see if your oem receiver has heat sinks on the sides. This may indicate the receiver powers the speakers with just one amp powering the sub, which is the same setup as mine.
Old Feb 26, 2005 | 08:27 PM
rainman15's Avatar
They are going to refund my money, but the wasted time is worth more than the 20 bucks to me. I did pull my stock deck out to look at the connections. It has a rectangle shaped plug on the top left corner and a long thing plug in the middle. I still have the harness from my 03 Lightning on the deck I intend to use and I pulled the expy deck to verify it wouldn't work prior to trying to order a new harness. As for the heat sink on the sides I don't exactly know what that means.
Old Feb 27, 2005 | 04:08 PM
MattStarr's Avatar
http://www.crutchfield.com/S-yFfIA7O...fo&i=120705517
Installed it and it works perfectly. It really brings the OEM little sub to life!
Metra 70-5517 is the number.
I think its only for 99-01 Expy's though. My stock radio had the heat sinks on the radio, so I figure only the sub was ampd. Anyhow, works great!
On the RCA cable, i see the red plug, thats ok, but what are the gray and black wires for coming from that harness... where do they go? thanks MATT
Old Feb 28, 2005 | 11:20 AM
Buzzz's Avatar
The black goes to the GROUND on the other harness. And the gray goes to the REMOTE or AMP REMOTE on the new receiver harness.
I had to call on that too, was a little unlclear.
