Rear Eng problems on '03 Exp
Rear End problems on '03 Exp
Well on 4th trip to dealer, first two was to fix a snapping sound from left rear which was a TSB on a new locking nut (guess that goes between half shaft and wheel hub). Now other side is doing the same.
TSB didnt work though, going for new half shaft, bearings, hub etc.. but parts are scarce.. guess common problem ? Tolerance issue on the spline ?
Any info welcome.. JR
TSB
There's a TSB for the clicking noise in the rear. I was told there's a tolerance issue between the half-shaft and the wheel hub, locking nut assy. I had the right side done last week and seems to be ok after 200 miles, but not the left side where they just changed the nut, it's starting to act up again. There also seems to be a shortage of parts as well.
fyi
Jerry
fyi
Jerry
