Long tube header fit.
Old Sep 11, 2002 | 10:32 PM
PERFORMANCE-RED's Avatar
I am thinking about putting full length headers on my 93 full size bronco.
Has anybody done this to there Bronco or f-150? What fit troubles will i run into? Is it possible to run true dual exhaust?
I have a ton of questions i am just curious if anybody could help out.
My Bronco is:
93 Full Size
5.8L Automatic transmission
Off Road package
Towing package
If there is anything else you need to know to help me out just ask.
Thanks for everybody that helps.
Old Sep 13, 2002 | 05:53 PM
ANY BODY!!! any body any body????
Old Sep 16, 2002 | 12:22 AM
Fordman302's Avatar
You can run long tubes without a problem as long as they make them for your application. You might have a problem finding a shop that will make "true duals" for you depending on your location. You will need to buy 2 new catalatic (sp) converters. I would go with some high flows. I ran long tubes on my '92 F-150 true duals with 2.5" high flow cats on each pipe and I had them runnin as straight pipes (no mufflers) sound was pretty awesome I had a 302 is the only difference. I had 18" slash cut tips out each side.
