Reset Computer???
I just installed my Pacesetter Predator 3" cat back exhaust system and am installing a FIPK in the next few days. Do I need to reset the engine computer? If not how long does it take to adjust itself to the new equipment?
1998 F-150 XLT 4X4 Supercab
4.6L Auto
Ram Sidetrax Nerfs
Pirelli Scorpion AT 265/75-16
Pacesetter Predator 3" catback
Air F/X FIPK
Mobil 1 Tri Synthetic w/ Motorcraft Filter
4.6L Auto
Ram Sidetrax Nerfs
Air F/X FIPK
If you want to reset it (not a big deal, it'll relearn in a couple hindred miles or so) disconnect the negative battery cable, trun on your headlights (it'll drain any transient voltage) let it sit for a few minutes like that, 5 would be more than enough, then turn the headlight switch OFF first, again, turn the headlight switch OFF first, then reconnect the negative battery cable.
Good luck!
Good luck!
