2000 Ford F150 02- Sensors
Old Nov 22, 2021 | 12:58 PM
Holliday's Avatar
I was reading the Trans cooler line when I noticed I had an unplugged 02 sensor on the passenger side right under the passenger seat. I was trying to find the other end to plug back in but no luck. I was able to find the harness where the other o2 sensors are plugged into. Is there one main harness that all the o2 sensors run into or should I be looking for something else???
Old Nov 22, 2021 | 05:37 PM
What engine? Do you have a CEL? If so, post the codes.
Old Nov 22, 2021 | 05:51 PM
If it's a rear sensor, it won't affect the way it runs. All it does is monitor the cats for efficiency. The front sensor close to the exhaust manifold is what the PCM uses for control. You should have codes.
Old Nov 22, 2021 | 06:02 PM
Holliday's Avatar
The Engine size is 5.4. I don't have a CEL, I do have a SES light and an ABS ligh On.
Old Nov 22, 2021 | 08:42 PM
projectSHO89's Avatar
SES=CEL=MIL. Same thing.
What are the fault codes?
Old Nov 22, 2021 | 09:46 PM
That looks like the front sensor, not the rear sensor. That will definitely affect the way it runs adversely.
Scan the OBD2 and post the exact P-codes.
Old Nov 23, 2021 | 07:08 PM
Holliday's Avatar
These are the faults that I was able to pull off the truck.
Old Nov 23, 2021 | 09:09 PM
You have issues with all 4 O2 sensors.
Old Nov 24, 2021 | 07:08 AM
Holliday's Avatar
Where should I start to troubleshoot these issues?
Old Nov 24, 2021 | 10:41 AM
Roadie's Avatar
Google those codes and read the instructions.
Old Nov 24, 2021 | 11:14 AM
https://www.obd-codes.com/p0135
https://www.obd-codes.com/p0136
https://www.obd-codes.com/p0156
https://www.engine-codes.com/p1131_ford.html
Bank 1 is passenger side, sensor 1 is the front sensor.
