Mbrp question
Old Jul 27, 2015 | 07:32 PM
alex06's Avatar
Mbrp question
I am running the mbrp exhaust my question is looking for a little more sound out of it can I do anything to make it louder or do I have to replace exhaust? Other question any mufflers fit in this system with not much modification?
Old Jul 27, 2015 | 09:49 PM
Replace your cats with high flows.
Old Jul 27, 2015 | 10:01 PM
alex06's Avatar
Hmm any ill effects engine lights or running concerns?
Old Jul 27, 2015 | 10:17 PM
You may throw a P0420 and/or P0430, but a Gotts O2 mod would fix that.
Old Aug 16, 2015 | 11:25 AM
And a custom tune disabling rear O2 monitoring would harmlessly keep the po420 out. Just be sure to try to have the cats welded outside of the truck, remove the downpipes and install on a bench I mean so there is 0% chance of an exhaust leak. I've been there done that, PITA to weld on top of the cats while in the truck, leak leak leak.
Old Aug 16, 2015 | 03:12 PM
alex06's Avatar
Well here is what I am thinking of trying first seems cheapest and easiest just removing the muffler. Thinking right after stock y pipe putting on a y pipe into 2 pipes run them back to the mbrp pipes. Not sure what size I need to slip over factory pipe?
Old Aug 27, 2015 | 01:29 PM
alex06's Avatar
Well did it removed muffler replaced with y pipe and 2 straight pipes sounds awesome.
