reuse?
Old Feb 25, 2015 | 10:04 PM
pineapple2468's Avatar
reuse?
Well, I just finished installing my new go rhino steps on the truck and now I have an issue. My exhaust currently comes out in front of the rear tire and was installed after my previous need bars were put on. The new steps are longer and hit the exhaust tip. Driving around there is definitely a rattle. So I am either thinking of a way I could bend the exhaust a little more of a 45ish angle or just replacing it back to the stock location. If I go the second route, will I be able to reuse my muffler (dynomax bullet) or would I have to replace it?
Old Feb 26, 2015 | 01:15 AM
You can cut the pipe anywhere between the tip up to a few inches from the muffler outlet and install a new pipe. A muffler shop should be able to do this for you without costing an arm and a leg, they do have pipe bending machines.
