Cold aur intake
Old Jul 20, 2013 | 05:17 PM
Usmcjwg's Avatar
Cold aur intake
I put a afm cold air intake on my 150 supercrew 4x4 5.4 auto. About a month ago. I am now noticing my gas miles has dropped to 9 mpg from 13 and I have like a skip in my truck sometimes at highway speeds. Could this be coming from the intake? I have no engine lights on please help.
Old Jul 20, 2013 | 05:29 PM
Those things do very little good unless you have a tune for it. Plus, they can cause you to run in a lean condition, especially if your truck is a 2004 or 2005. What year is it?
How many miles on the plugs?
Old Jul 20, 2013 | 05:40 PM
jdeacon's Avatar
ditch the intake. may need plugs
Old Jul 20, 2013 | 08:07 PM
Usmcjwg's Avatar
2001 with 311100 miles plugs have about 40k miles on them but my truck over heated and blew water all over the engine a couple months ago do you think it could have shorted a coil pack? I've never changed the coil packs
Old Jul 20, 2013 | 08:10 PM
Usmcjwg's Avatar
If I put long tube headers on do away with cats put in an xpipe with dual exhaust get a custom tune with the air intake plus new plugs and all new coil packs will that breath some new found life in my old truck?
Old Jul 20, 2013 | 08:11 PM
Usmcjwg's Avatar
It would be alot cheaper than a new truck plus I'm attached to my truck got it new dont want to let her go
Old Jul 20, 2013 | 08:15 PM
thelariat02's Avatar
Fix the miss first before adding power adders. Also put your stock intake on till you get a custom tune for everything you want to put on it.
maybe also change all 4 O2 sensors with motorcraft ones..
Old Jul 20, 2013 | 10:16 PM
Usmcjwg's Avatar
Ok I've never changed them or anything else on the motor. Just plugs and a new intake when the old one cracked.
Old Jul 20, 2013 | 10:17 PM
Usmcjwg's Avatar
Where can I get a custom tube from everyone keeps talking about. I'm in South Carolina and if I get one so I need the truck there so they can use a laptop or will it plug in to my port under my dash
Old Jul 20, 2013 | 10:18 PM
Usmcjwg's Avatar
Tune
Old Jul 20, 2013 | 10:19 PM
Ya O2 sensors are usually changed at 100,000 or so.
I had all four of mine go within a few months of each other after I hit 100,000 miles..
Old Jul 20, 2013 | 10:21 PM
Custom tunes are email order tunes.
Go take a look over in the programmer section and read the stickies.
Old Jul 20, 2013 | 11:11 PM
Usmcjwg's Avatar
Ok thanks.
Old Jul 20, 2013 | 11:47 PM
c1t1d1's Avatar
Did you disconnect the batter when you installed it? It resets the ecu so it can learn the new air thats coming in.
Old Jul 21, 2013 | 12:34 AM
Usmcjwg's Avatar
No but I will try that.
