05 5.4 Bad Cat and Exhaust question
I've had some rattling on the underside of my truck for a few months now and finally took it in to a mom and pop shop to have it looked at. I got a call that the catalytic converter has gone bad and was causing the rattle. I thought this might be the case since I had a code a few months back about the cats. They said that Ford charges $1,400 but they could get one from Napa for $400.
I told them to hold off since I live in a city that I don't have to go through inspections. I want to replace the exhaust system anyway since its stock.
At this point, would I just need the midpipe, cat-backs and the O2 sensors? He warned that my mpg would go way down, but I dont see that happening as bad as he says.
Also, if I go that route, would I need to get a custom tune for my Edge? I am running the tow tune now.
Thanks in advance.
Thanks in advance.
Well, I spoke to a muffler shop and they said that the welding could not be done when I asked. They also quoted about $1,400 also to replace.
What options (other than the welding) do I have?
Get out of the city area and take it elsewhere. The downpipes need removed for installation, and it should cost a max of $200 for the work, $160 for the cats tops.
Much more exhaust leak proof also!
Well, the problem may have solved itself. After doing a little more searching on this site, I found a post that linked to an EPA warranty on vehicles built after 1996 that has a federal warranty on emissions components. I'm lucky in the fact that my truck is a 2005 and has 77k on the clock.
I called my local dealership and the service guy knew about the warranty and they are going to fix free of charge.
Here is the link to the EPA warranty.
http://www.epa.gov/oms/consumer/warr95fs.txt
