Any custom exhaust experts out there?
Old Mar 31, 2012 | 06:46 PM
4.2xl2001's Avatar
I bought some parts to assemble a single, stainless steel, custom-bent exhaust system for my truck. I just found out that the parts that "fit" my truck are actually different diameters. The center and tailpipe are 2.5" (what I wanted for my V6) and the muffler is 3" in/out. Here's my question:
Can the 2.5" pipe be expanded, by conventional means, to fit the 3" muffler inlet/outlet? A SS adapter is available but that would require trimming of pipes, additional cost and clamps or welding etc. I would borrow an exhaust pipe expansion tool from Autozone, if that would work.
Old Mar 31, 2012 | 07:28 PM
It can but expanding it a quarterinch end to end to make it a half inch bigger is going to weaken it over time to rot out and leak. Trimming isn't so bad with good blades and clamps.
Old Apr 1, 2012 | 12:51 AM
avfrog's Avatar
You would expand the 2.5" to fit inside the 3". No big deal.
Old Apr 1, 2012 | 02:58 PM
4.2xl2001's Avatar
Thanks, I'll give it a try. If it works, I'll save $100 in the cost of 2 adapters and additional clamps. Stainless steel isn't cheap.
Old Apr 1, 2012 | 08:42 PM
avfrog's Avatar
If you bought 409 stainless, then your screwed. It will split before you get it expanded that much. 304 should be just fine.
Old Apr 1, 2012 | 10:05 PM
4.2xl2001's Avatar
The tubing for the centerpipe specified T304. The Magnaflow tailpipe didn't specify...I will call the seller tomorrow for that info.
