Gotts mod is this common
Old Feb 19, 2012 | 07:34 PM
stevo198914's Avatar
So after reading about the Gott's mod i decided to pull the trigger and do it figuring if i didnt like it, it would be easy to go back to stock. anyway after i installed everything and took it out for a test run i couldnt believe the diference it had made, but whenever i went to stop my truck wanted to stall out im just wondering if this is a common problem or not
Old Feb 19, 2012 | 09:11 PM
CRDick's Avatar
Didnt experience this on my 01. Did you disconnect your battery and let the computer reset itself. Have read some about later trucks running lean, does this apply to your model????
Old Feb 19, 2012 | 10:11 PM
1997 lariat 4.6's Avatar
eh no, mine didn't want to start until i unhooked the battery and reset the system.
Old Feb 19, 2012 | 10:13 PM
Yea i did disconnect the battery and i have a 05 so im not sure if this applies to my year or not
Old Feb 19, 2012 | 10:24 PM
Clean the MAF and throttle body.
Old Feb 19, 2012 | 11:50 PM
NickArellano97's Avatar
my truck never did that. nor did my cousins husbands f150. I dont think it is common. but try cleaning the MAF and TB.that would probably be your best bet
Old Feb 20, 2012 | 02:24 PM
spencer95's Avatar
leak after maf?
Old Feb 20, 2012 | 02:44 PM
buck119fa's Avatar
First what size motor are you talking about? if it's the 5.4 3 Valve try reading this link...https://www.f150online.com/forums/ar...3-f-150-a.html
post #6 states "the 3 valve motors require the tuner for the intake mods
I would recomend an Xcal2, Xcal3, gryphon or diablo with custom tunes for you and your truck VS canned tunes even though a tune would not be required to see benefits from this mod (you will see more increase with a tune)"
Post #95 on page 7 also.... "
Quote:
Originally Posted by XtremeBawls
So the 97-03's don't have problems running lean with this mod like the 04-08's?
It is actually just the 04-05s with the 5.4 3v.
Hope this helps
Old Feb 20, 2012 | 06:41 PM
I have a 05 4.6L with sct custom tunes already so i dont think that can be the problem
Old Feb 20, 2012 | 06:51 PM
Jughed's Avatar
All the electronics plugged back in?? I had no issues when i did mine on my 97 or 04.
Old Feb 20, 2012 | 07:40 PM
Dog'em's Avatar
I actually pulled a K&N system off of my 05 with the 5.4 because of the lean problem frying my plugs. Did the Gotts mod and have not had any issues even without a CAI programmer .
Old Feb 20, 2012 | 07:50 PM
buck119fa's Avatar
with the 4.6 you should have been good. check all the connections to the hoses and wires, clean the TB and MAF. make sure the clamps are tight, other than that?? Just wondering... can you put your tune back to stock, run it and see what it does? If that cures it, disconnect the battery again, wait a bit, reconnect it and the reload your program. Just a thought...
Old Feb 20, 2012 | 09:13 PM
tbear853's Avatar
The "Gotts" mod does not lead to a lean condition, it does not require a tune, it does not change the location of the MAF as related to air filter or TB ...
... all because it does keep the stock filter box, all it does is change the snorkle.
CAIs need some tuning because they change the air filter, housing, yubing, location of MAF as related to filter and TB. They change everything in front of the TB.
Old Feb 20, 2012 | 09:19 PM
Well I have 59000 on my truck now , would it hurt to clean the tb and Maf with not that many miles on it. If so I will do it tomorrow and see what happens from there. And yes I can change it back to stock and try that also
Old Feb 26, 2012 | 11:36 AM
Well after cleaning the MAF and TB i still have the problem that my truck wants to shut off when i stop in drive or reverse and im beginning to think that it could be my ideller pulley has any one had this problem and did it fix the problem
