Muffler Shops won't install Hi Flows
Old Aug 24, 2011 | 06:42 PM
tjmud2's Avatar
Sorry if this has been asked before but I did several searches and came up empty handed. I bought the 94106 Magnaflow Hi Flow Converters for my 99 F150 SC 4x4 with the 4.6L V8. I went to two shops and they both said that they wouldn't install because I didn't buy the Magnaflows from them, and there was not enough profit in just he labor to complete.
Can someone please outline the install process of the Hi Flows because both shops put the truck up on the lift and said that they couldn't do it as they would not be able to weld all the way around and make a perfect seal with no leaks.
I had thought make a cut right in front of the first cat, and one right after the last cat. Put the new hi flow cat in the middle, and piece in pipe between the cat and O2s. Both shops acted like they needed to take the exhaust all the way off from the manifold flange, remove all 02s, and drop it down to make complete welds.
What am I to expect for installation, can they not complete without removing everything? My truck is very rusted and I am sure that things will start breaking when trying to remove flanges and 02s.
Do they need to remove the 02's and weld in new bungs?
Any advice would be appreciated on the install process.
Old Aug 24, 2011 | 06:51 PM
azmidget91's Avatar
they are right, cut right before first cat, tack weld in the cat and extra pipe, weld in o2 bung, drop exhaust from manifolds to fully weld and then bolt back up
keep looking you will find a shop that will do it
Old Aug 24, 2011 | 06:59 PM
x2!....
Old Aug 24, 2011 | 09:56 PM
avfrog's Avatar
x3! Those 2 shops are too damn lazy to do it apparently.
Old Aug 24, 2011 | 10:34 PM
tjmud2's Avatar
Is there anyway to do it without dropping the exhaust from the flanges? My exhaust is completely rusted and if we need to remove at the flanges and remove the O2 sensors to drop then I'm afraid I'm out of luck as the rust will cause everything to break. Nice Midwest Salt in the Winter.
I was hoping to cutout and weld up the hi flows in place.
Old Aug 24, 2011 | 11:46 PM
avfrog's Avatar
If he was a good welder he could do it without dropping it down. a simple mirror, and you can see to check the weld on top for holes. I am a welder, and it can be done, if your good.
Old Aug 24, 2011 | 11:49 PM
I'd keep shopping around....
Old Aug 25, 2011 | 12:32 AM
97XL's Avatar
I had the same issue, had to go to 3 shops before I found one that would install mine. The excuses I got were, "It's illegal and we can get fined." They welded mine in place with no leaks and that was 3 yrs ago.
Old Aug 25, 2011 | 11:01 AM
azmidget91's Avatar
i guess its possible to weld it in place but if it were me id drop the exhaust
Old Aug 25, 2011 | 12:53 PM
4.6 Punisher's Avatar
Agreed, that's how my exhaust guy does it. Probably not as good as dropping the whole system.
Old Aug 25, 2011 | 09:05 PM
avfrog's Avatar
^ Looks are irrelevant on the top side of the joint. No leaks is what is important!
Old Aug 26, 2011 | 04:33 PM
Drizzle's Avatar
to the original poster...I feel your pain man. I bought a set of those same cats a couple years ago and basically got the same responses from local muffler shops. Some said they couldn't do it at all because it was illegal, and the ones that said they would do it, took a look at it, and said they would have to take the exhaust manifolds loose and drop the whole thing to weld it correctly. They said they couldn't physically fit the welder wand in between the cat and the heat shield to weld the top side...hence their reasoning to drop the whole exhaust system first. I basically walked away and returned the maggie cats I bought when guys started saying "yeah I can do it...but I'm not sure you want to pay me to do it".
It just wasn't worth it to me so I said forget it.
Old Aug 27, 2011 | 12:59 PM
x2 on dropping form the downpipes. My old trucks exhaust leaked at the rear converter deletes. Drove me nuts, probably robbed a couple MPGs.
Old Aug 30, 2011 | 01:38 PM
tjmud2's Avatar
Went to another shop today, he seemed more confident and talked a good game. In short, $120.00 per side ($240.00) total, but he keeps the cats, thats the only way he will do the work. He scraps them out and keeps the money, so he said if I must have the Cats, then I need to go somewhere else. So does $240.00 sound reasonable?
Installation would be unmount at the manifold flange, and cut right before the rear O2 sensor. remove all 4 cats, weld in the 2 new ones, mount back up to the flange, and weld in before th O2 sensor. This will require him to only remove 2 sensors instead of 4.
Opinions? Does he sound reputable? He was recommended by 3 shops, and does custom exhaust work on hot rods.
Old Aug 30, 2011 | 01:48 PM
It's sounds like he knows he's good and he's going to charge you for it.....depending on where you take them for salvage....I think he's hi......keeping the cats to boot.....
