Exhaust length Advice
Old Aug 15, 2011 | 01:46 PM
Trav1500's Avatar
Ive got 2 1/2in pipe exhaust with a dumped universal single chamber magnaflow and i just deleted the rear cats ...i was wondering while ive got it all unhooked if i should cut it where ive only got about 3-ish feet of pipe before its dumped. Right now the openings about a foot from the rear axle. Will it enhance the rumble at all? And im completely naive on backpressure, will it effect my torque to much if i cut it short? Thanks
Travis
Old Aug 15, 2011 | 02:38 PM
4.6 Punisher's Avatar
If you want it louder on the outside as well as the inside, have it exit out the side or back with a tip. Shortening the dumped pipe will just make it louder inside the truck and increase drone.
Old Aug 15, 2011 | 07:36 PM
Trav1500's Avatar
Gotcha, thanks. So Extending it out wont decrease the rumble/volume? As of right now i dont have a tip on the end, any suggestions for tip sound? Or do tips really even have an effect...
Old Aug 15, 2011 | 11:09 PM
avfrog's Avatar
Bigger tips, bigger sound. No other way around it.
Run you a pair of tip out in front of the rear tire and smile. Dumps kill your sound.
Old Aug 15, 2011 | 11:10 PM
avfrog's Avatar
Torque, hp, and mpg will NOT be affected.
Old Aug 18, 2011 | 08:01 PM
Trav1500's Avatar
Great thanks! Appreciate the info! Im going leave it dumped till i can afford true duals, ill be puttin a good sized tip on there within the next few weeks.
Old Aug 18, 2011 | 09:30 PM
avfrog's Avatar
good, good
