Have you ever seen a downstream o2 look like this?
I was getting
P0138 O2 Circuit High Voltage (Bank 1, Sensor 2)
P0054 HO2S Heater Resistance (Bank 1, Sensor 2)
P2271 O2 Sensor Signal Stuck Rich (Bank 1, Sensor 2)
I replaced all the o2's for good measure.
Both fronts and the driver's side downstream looked fine (but had a tiny amount of white caked fouling, but not much at all).....but the passenger side downstream.......
The driver's side taps into the exhaust pipe from the top, at a 45*and is about a foot after that bank's cat. The passenger side taps into the pipe directly from the side at the 3 o'clock position and is directly behind that bank's cat about 3". I have magnaflow hi-flow cats. Both of the front o2's looked totally normal.
I have been keeping an eye on my coolant and oil levels, and everything is and has been kosher for months. I have used in-tank fuel injection system cleaners before, could that do this?
If the cats were bad, after changing all the o2's and clearing the CEL's, wouldn't it throw catalyst codes?
I got this response from a non-F150 forum I frequent, that attracts lots of tuners familiar with modified Fords
Originally Posted by gmorrell
OBD2 monitors the heater current to the sensors, if it threw a P0054 HO2S Heater Resistance code, then that sensor may have an open heater, if so, it wasn't operating at proper temp and might have fouled. Downstream, post-cat O2's don't get the exhaust heat benefit of the upstream sensors, so they need more and constant heater current to stay at operating temp and be self-cleaning. This could also be a blown O2 sensor heater fuse, or problem with the PCM, but if the other 3 sensors didn't have this appearance, I'd be suspicious of just the one sensor..
