Mississippi??
Old Apr 4, 2011 | 10:14 AM
grantcar16's Avatar
Mississippi??
Im running into problems getting a inspection sticker because there is a new law that your tent has to be 28.0 and mine is 18.0.. I hate to start reppin off my tent and everything haha. I've tried the rolling down the windows trick and everything in the book.
I was also wondering is it legal in Mississippi to only have 2 cats? Replace the 4 cats with 2 high flow cats? Help
Old Apr 4, 2011 | 10:37 AM
NCSU_05_FX4's Avatar
Physically remove your windows.
I did that and passed in NC.
- NCSU
Old Apr 4, 2011 | 12:01 PM
grantcar16's Avatar
Haha did you really?
Old Apr 4, 2011 | 06:26 PM
Yup. See here: https://www.f150online.com/forums/ge...ndow-tint.html
- NCSU
Old Apr 5, 2011 | 01:28 AM
Toyz's Avatar
I was thinking of a camping tent... I was like, wth do you need a tent to pass inspection for.
Old Apr 5, 2011 | 09:46 AM
grantcar16's Avatar
haha dang, but really, Here in mississippi there thinking about doing that inspection with checking out the cats and all that, would i need all four cats or could i replace the 4 with 2 high flows?
Old Apr 5, 2011 | 11:08 AM
Blue07STX's Avatar
Technically, it is against the law to remove a properly functioning cat converter.
Rules for Replacing Converters
In 1986, the U.S. Environmental Protection Agency issued new guidelines for the construction, efficiency and installation of aftermarket catalytic converters. All CleanAir converters listed in this catalog have been designed, tested and manufactured to meet this policy.
In addition, CleanAir converter listed in this catalog is appropriate for use under the current requirements of the California Air Resources Board (C.A.R.B.).
E.P.A. guidelines state that replacement converters may be installed only in the following situations:
1. The vehicle is missing a converter
2. A state or local inspection program has determined that the existing converter needs replacement
3. Vehicles manufactured prior to 1996 must have more than 50,000 miles, and a legitimate need for replacement must be established and documented
4. In cases of OBD Il-equipped vehicles (1996 and later), the O.E. manufacturer's 8-year/80,000-mile warranty must have expired and a legitimate need for replacement must be established and documented.
Please note that Federal law prohibits removal or replacement of a properly functioning O.E. converter.
When replacement of the converter is appropriate (as outlined above), the E.P.A. further requires that:
1. It be installed in the same location as the original
2. It be the same type as the original (i.e., two-way, three-way, three-way plus air/three-way plus oxidation)
3. It be the proper model for the vehicle application as determined and specified by the manufacturer
4. It be properly connected to any existing air injection components on the vehicle
5. It be installed with any other required converter for a particular application
6. It be accompanied by a warranty information card to be completed by the installer.
http://www.epa.gov/compliance/resour...amccpolicy.pdf
The EPA is out in force these days. A local performance shop was fined for removing properly functioning cat's a few years ago.
Just a thought.
Old Apr 5, 2011 | 11:36 AM
grantcar16's Avatar
dang thats crazy, thanks for the info man!
Old Apr 5, 2011 | 12:40 PM
DJ2007's Avatar
Old Apr 5, 2011 | 08:15 PM
Lanem3's Avatar
Not sure about the tint, however I live in the Jackson area.. and as of 5 days or so ago I'm running 2 converters with a true dual x-pipe and bullets.
