magnapack install questions
Old Feb 27, 2011 | 04:32 PM
socomboy's Avatar
Hi guys. I'm really digging the sound of the magpack and i'm considering getting one. I just wanted to know since the pipes are offset/offset would this be possible since i will be running SI/SO. Also if it can be done can someone just give me s rough estimate of an install price? I was thinking between 50 an 80 bucks maybe?
Old Feb 27, 2011 | 05:15 PM
4.6 Punisher's Avatar
The guy at the shop will have to bend a piece of pipe since the Magnapack is a lot shorter than the stock 50 gallon drum. $50-$80 sounds about right if all you are doing is a muffler swap. It might be a little more if you are also adding a nice tip, but not much more.
Old Feb 27, 2011 | 08:19 PM
edwards1687's Avatar
I got my SI/SO Magnapack installed a month or two ago for $140 out the door. They cut the rear two cats off and ran new pipe from the front two cats back; along with installing a new Y-pipe and 4" tip. I had about $230-240 in the setup for parts + install and I couldn't be happier with how it sounds.
