Cat removal
Re: Cat removal
Originally posted by 05RedFX4
Does anyone know if you will get any computer faults from removing the cats on an 04/05 with a 5.4 3v
You can remove back 2
Yes you can remove the back 2 converters with no problem whatsoever, but not the front 2. I have removed the back 2 with a magnaflow siso. It runs fine, but I would hate to have any less backpressure than what I have now.
trick?
Hi.
Can you please describe what you think you will accomplish by doing this?
If this remains a hypothetical question, then the answer is Yes, and you can summarily ignore the following diatribe. If not, then read on...
Better flow? No - the stock cats flow pretty well on a stock motor.
Better performance? Nope - none that you'd notice.
Noiser? Yes , but with the stock muffler, not by much.
Coolness factor? Perhaps on a planet where the sky is a different color.
Add even more pollution? Yup. Ohio and everyone downstream ( that includes me) certainly needs more of that, eh?
Seriously, the trick here, to avoid a socially irresponsible blunder such as this, is to reconsider what it is you are doing.
At least consider, if you have this burning need to f**k with your cats, replacing all 4 with a pair of high-flow ( Magnaflow, for example) units. This is the proper way to deal with this. Not necessarily for performance (with your mod level, you won't see any) but to ensure the emissions remain acceptable.
Future generations will thank your contribution.
All things are possible - but not all things that are possible are smart.
cheers
cheers
Removing cats is a Federal offense, the fine is substantial. It's something like $2500 per removed cat.
Re: trick?
Originally posted by MGDfan
Hi.
cheers
Hi.
cheers
sounds like someone needs a... HYBRID...AWWWW
if i was worried about emissions i wouldn't buy a big truck...i'd bought a PRIUS.
Nice...
Hi Pay;
Actually, my 2000 F150 posts better emissions results than my 1988 Mustang GT ;-)) And carries *way* more topsoil !
Seriously - it's not good to eff with those cats unless you preserve the intent of them being there in the first place.
"Not getting caught" is perhaps the dumbest excuse for a response I've seen in quite some time. I need Max to jump on this one as only he can do... fresh meat !
Cheers
Cheers
Re: Nice...
the point i was trying to get at was that if his main concern was the environment then he'd be fine with a hybrid, but obviously his main concern is (what most of everyone in america's is) what he likes...he doesn't like a hybrid, he wants a truck...and if he wants a big truck that sounds nice and has a little ***** to go with it who should fault him...IMO if you want to make the most impact with this "save the environment" stuff you should head over to the SuperDuty page and start on anyone who owns anything with the words "PowerStroke" in it
...i just find it hard to get all worked up over the minimal difference in emissions between being catless and with cats and what all of black smoke from a diesel...i could probably run my truck to work and back for a year without cats and the difference in me having cats would be less than one diesel making a quarter mile run at the local track. hope i didn't get anyone's panties in a bunch i just don't see all the need for a fuss over losing 2 of the 4 cats you have if it's what you want to do with your own truck...
Originally posted by Lifted98Ford
Hey dsp921 I was wondering how you would ever get cought for not haveing cats?? I have no cats on my truck and i didnt have any on my mustang 5.0 i had and i never got cought?
emissions
Hi!
Well emisions has never been a real problem because we don't have any kind of organized inspection here in Arkansas. They reserve the right to pull any unsafe car over on site. This means if you are really loud or smoking really bad they will stop you. (This is good and bad IMO) However...the truck has 4 converters on it. Have you seen the inside of these things? HARDLY promote good exhaust flow. Now the front two could never be touched, but when I removed the back 2 and put on a Magnaflow SISO I felt a real seat of the pants difference. There is also no annoying drone or anything else as I left the exhaust exiting the rear. While I would not intentionally harm the environment (I depend on the land for a living), I don't think my removing 2 of 4 converters will kill any trees around here. But cars do have exhaust emissions. You are harming the environment everytime you fire that baby up. Perhaps a bycicle wouldn't? Of course a steel mill and a rubber factory had to produce the bycicle and tires, so that would be some emissions too? Maybe you could turn Amish and walk. Just my observations...not to offend anyone.
DEL
DEL
Is there a way to trick the computer so it doesn't register a fault
http://www.fordmuscle.com/archives/2...ale/index.php#
scroll to the bottom of the page and click on "make your own" and it'll give you a wiring diagram with radioshak part #'s.
