Quick question about converters...
Old Feb 24, 2011 | 09:00 PM
SupercrewLightn's Avatar
Question Quick question about converters...
Ok guys, I am bummed because as most of you know I just had the exhaust done on my truck. I noticed a slight rattling sound about a day after I installed it, and it has been getting progressively worse. I checked all the heat shields and all are tight and no rattling. I took it to the exhaust shop and sure enough we figured out the right hi-flow cat puked and the internals are broke and rattling. I am having him remove the internals from the cat next week and rewelding it in. So here is my question- is there anything wrong with having one gutted cat and one non gutted cat? obviously the right side will flow a bit better, but should I have him go ahead and gut the other one too? (no emission tests here)
Old Feb 24, 2011 | 09:09 PM
jbrew's Avatar
I say no way, -UNLESS you can get tuned for it. Not sure if it will be a benefit. I might weld in my rear factories, -if you still have them. So I could keep my currant tune. They're a better converter anyway and flow about the same IMO. Compare them with a flashlight, you'll see. The factory rears might be a little longer, can't recall.
I would definitely check with my tuner and inquire either way.
Old Feb 24, 2011 | 09:12 PM
Nope my rear cats are long gone.. It only has the two high flows now.. aaand it just so happens I just got my programmer from vmp today and will start data logging next week so he can make me tunes for it. So tuning for it is not an issue..
Old Feb 24, 2011 | 09:18 PM
jbrew's Avatar
I'm not sure, - Mid range and High end shouldn't be a problem. I'm not sure about the Low end. Low end is most important to me tho, so I would talk with a tuner about it.
Old Feb 24, 2011 | 09:21 PM
Yeah I'm not so worried about the loss of power as much as having one gutted cat and one non-gutted cat.. I don't see how it could hurt anything being that they are both high flow cats...
Old Feb 24, 2011 | 10:16 PM
avfrog's Avatar
Your o2 sensors will read differently, and might throw a code.
Old Feb 24, 2011 | 10:40 PM
I'd just get maggie hi flows put in if you haven't already. Just get an identical one to the one you have at the very least so they are the same
Old Feb 25, 2011 | 12:08 PM
jbrew's Avatar
Didn't you just install new high flows ? They should have some sort of warranty.
Yea, you'll have to get your cat checkers turned off (rear O2's). If you gut them both, I don't think your going to like it. I tried it with the factory tune and mine ran like schlitz, - fell on it's face, no low end..
Old Feb 25, 2011 | 09:24 PM
What about with a custom tune?
Old Feb 25, 2011 | 09:59 PM
jbrew's Avatar
Post #4. ^^^
Old Feb 25, 2011 | 11:08 PM
Post #4. ^^^
Yeah that's what I need to do, I've actually been trying to get ahold of justin @ vmp for three days by phone and email and can't get through to him... maybe he's gone or something..
Old Feb 28, 2011 | 12:26 AM
I think I decided to just put a new set of hi-flows in, it just doesn't seem like a good idea to gut em...
Old Feb 28, 2011 | 01:07 AM
jbrew's Avatar
Smart IMO. You've invested quite a bit in her, why cheap out now... Not sure what happen to your High flow tho, - why did it fall apart ? Weren't they new ?
Think I asked that already..(?)
Old Feb 28, 2011 | 09:52 AM
Sorry Jbrew, yes you did ask that.. the cats were not brand new, they have about 35k on them, which still seems weird that one would fail so soon.. I'm not sure what made them fail, maybe I was running too rich for a while before the tune and burned it out. I can't figure it out
