Cat code question
Old Jan 31, 2011 | 08:41 PM
Weber27's Avatar
Cat code question
I took out my cats and put in hi-flows about 8 months ago and they sounded great and I had not problems. I just recently got an edge programmer for the towing setting and to run a little stronger and after a week of using the programmer my check engine light has come on and the code its throwing is referring to the catalytic converts. I rest my truck to the stock settings and the code goes away. Anybody have an idea of what it may be or if I can still run my programmer with my hi-flows?
Thanks guys!
Old Feb 1, 2011 | 09:06 AM
Weber27's Avatar
Need help has anyone had this problem with the hi-flows and edge programmer?
Old Feb 1, 2011 | 09:56 AM
rllackey28's Avatar
Mine throws a P0420 code now but it didn't until I had my exaust rewelded. The welds were leaking around my cats and have had this code on and off since. I just assumed it was a welding issue. I might try to set it back to stock and see.
Old Feb 1, 2011 | 12:43 PM
Weber27's Avatar
Ya I put my truck back to stock and the light went off. Once i switch it back it takes a little while but then the light comes back on.
