should I make a heat shield or leave it alone?
Old Dec 22, 2010 | 03:56 PM
rcantu's Avatar
I put together a 4 inch intake for my set up and looking at where the filter sits i'm not really sure i could spend the time to make a heat shield. filter is crammed next to the radiator overflow tank and cruise control module.
what do you guys think?
Old Dec 22, 2010 | 05:38 PM
avfrog's Avatar
That is not really going to make much of a difference while your driving down road. It will get cooler air regardless.
Old Dec 22, 2010 | 05:47 PM
beechkid's Avatar
25 Year Member
If you live in a hot climate (90 degrees+) and do alot of city traffic I would build one from the standpoint of not to cool the air but to protect the plastic intake from possible heat distortion.
Old Dec 22, 2010 | 09:24 PM
Blue07STX's Avatar
I recommend a shield or you may ingest water in heavy rain.
Old Dec 22, 2010 | 11:04 PM
justin mccluske's Avatar
I built this for mine.... Seems to work pretty well.
Old Dec 22, 2010 | 11:27 PM
avfrog's Avatar
^ Why the foam inside of it?
Old Dec 23, 2010 | 01:01 AM
The aluminum was getting hot so I put the foam in there as an experiement to see if it would stop some of the heat from getting in and it seems to work. I would feel the filter and intake pipes after driving around and they would be hot and sence I put the foam in there the filter and intake pipes feel nice and cool.
Old Dec 23, 2010 | 03:52 AM
rcantu's Avatar
I'm gonna fab one up and see the difference.
Thanks all
Old Dec 23, 2010 | 10:11 AM
avfrog's Avatar
But did it lower your intake temp?
Old Dec 27, 2010 | 02:44 AM
sbchris's Avatar
If you don't have an inter cooler the ambient air temp is the least of your concerns...
