K&N Air Filter??
Old Dec 10, 2010 | 10:59 PM
bansheerider's Avatar
K&N Air Filter??
I am new to the F150 community so please excuse my ignorance. I was wondering if the K&N filter really does help with the performance of the truck. They say it does but I would rather hear from peoples experiences. Thanks!
Old Dec 10, 2010 | 11:07 PM
canadian_screw's Avatar
No. The ONLY reason I run a k+n filter is so I dont have to buy a $30 paper filter every 6 months
Old Dec 10, 2010 | 11:46 PM
WILDMAN442's Avatar
I think youll find the general concensus is that they are not even close to worth it.
A lot of people have recomended the Amsoil Filter though. Seems to be a decent product.
Justin
Old Dec 11, 2010 | 01:22 AM
jbrew's Avatar
Yep, -the Amsoil dry element nano fiber is #1 and basically maintenance free.
Old Dec 11, 2010 | 06:31 AM
shotgunz's Avatar
Amazon has the FA-1883 for $18 with free shipping.
Justin
Amsoil doesn't offer them for the 09-10s. They 'recommend' a Wix.
Old Dec 11, 2010 | 08:10 PM
Thanks for the info guys. Can you tell me what a wix is though?
Old Dec 11, 2010 | 08:13 PM
Micheal's Avatar
Wix is a "brand" of filters.
Old Dec 11, 2010 | 08:21 PM
jbrew's Avatar
Yea, it's WIX/NAPAGold. = Same
Old Dec 11, 2010 | 08:49 PM
No real performance help but I've been running the same K&N filter since early 2004 when I bought my truck. Close to 100k miles on it now with no problem's. Just don't over oil them after cleaning!
Old Dec 11, 2010 | 10:09 PM
gDMJoe's Avatar
Contaminates the MAF ( no matter how careful you are (re)oiling ) and any performance claims are ...
Old Dec 12, 2010 | 04:06 PM
openclasspro#11's Avatar
close to 300 k miles on my k&n, never a maf issue
Old Dec 12, 2010 | 04:14 PM
Yep, I have 112,000 on mine. Never an issue. If you don't over oil, it will not foul the MAF. Some people just do not understand what "lightly oil" means. My truck still does not burn oil either. No, no performance gains but sure save a lot on filters.
Old Dec 12, 2010 | 07:31 PM
expy03's Avatar
If you do some research, you'll find that many folks have issues with their MAF, and throttle body assy's that have never used a K&N. It's a product of blowby from the oil causing the contamination along with all kinds of other elements that make it through the filter. I have removed 2 seperate maf's on vehicles with a K&N and wiped the intake tube with a clean white t shirt and have yet to come up with any oil. Is it possible to over oil the filter? Sure. Just like over filling the crank case, transmission, to much air in the tires, etc. Just have to do it right.
http://www.aa1car.com/library/maf_sensors.htm
CLEANING FORD MAF SENSORS
For some reason, Ford vehicles have had a history of MAF sensor problems caused by contamination. In some cases, dirt gets past a leaky air filter and fouls the sensor wire. In other cases, carbon varnish builds up on the sensor from fuel vapors backing up through the intake manifold. Either way, contamination makes the MAF sensor sluggish, and often sets a P0171 or P0174 lean code.
The fix is to clean the sensor element with aerosol electronics cleaner (CRC makes a good product for this). The MAF sensor is located inside the air filter housing on some applications (Windstar, for example) or between the air filter and throttle body. Spray the sensor element with electronics cleaner, let it soak for about 10 minutes, then repeat. DO NOT use any other type of cleaner as this may damage the sensor. Also, DO NOT touch, scrub or attempt to physically clean the sensor element as this too can ruin the sensor.
Old Dec 12, 2010 | 08:05 PM
mSaLL150's Avatar
What products do you guys use to clean and re-oil the K&N filters and where to get them? Mine needs it bad. Also what particular product do you use to clean the MAF sensor successfully?
Old Dec 12, 2010 | 08:16 PM
jbrew's Avatar
Some info -
http://www.knfilters.com/search/prod...x?Prod=99-5000
Where to purchase - Just look up "K&N Recharge kit". Many places sell them.
MAF- That depends how well you want to clean it. I believe there's a "How To" on this site.
I use duplicolor "paint prep" ,mineral spirits or denatured alcohol. IF the MAF has a hardened (cooked on) coating, - like shell. Carefully use lacquer thinner to cut.
Never use an aerosol hose down made by CRC. It will leave a milky white residue. You have to clean the wires by hand if you want to do it any justice. Don't be afraid lol.
