Which has less issues -stock manifolds or aftermarket headers?
Old Dec 10, 2010 | 12:14 PM
rcantu's Avatar
My 01 with JBA shorties are leaking and I was told since they do not make any power and are low quality so I should put back stock manifolds. I would have to buy stockers if I did but then I've read complaints of the stock manifolds cracking or also having leaks.
It seems either way is going to be a big fail in the end. Maybe another aftermarket brand may be better?
If any body has some thoughts on what I should do I really appreciate it.
Old Dec 10, 2010 | 12:21 PM
IR0NS1N's Avatar
Have you tried just tightening the bolts? You have to randomly check the bolts on headers over time. I wouldnt go manifolds as they warp and crack.
Old Dec 10, 2010 | 12:28 PM
rcantu's Avatar
i haven't had a chance to do a check yet. I just fixed some other leaks from the catback. I plan on tackling that this weekend.
that's what i read about manifolds too so it's problematic for stock and aftermarket then.
thanks
Old Dec 11, 2010 | 01:35 AM
jbrew's Avatar
Replace the trans mount and you won't have a problem with the stock manifolds. Lightning manifolds are a little heavier as well. Well, not heavier, stronger design.
BTW, - Header bolts can require up to 4 stage tightening. From the center out and between drive cycles. They will hold torque value @ stage 4.
Old Dec 11, 2010 | 12:47 PM
rcantu's Avatar
thanks for the advice guys.
Old Dec 11, 2010 | 02:16 PM
shifty_85's Avatar
just dont rail on them member your tightening into Aluminum!!! They will strip out very easily
Old Dec 11, 2010 | 03:10 PM
jbrew's Avatar
That's why there's torque specs
Old Dec 11, 2010 | 10:33 PM
rcantu's Avatar
ok i attacked the headers today. it was the passenger side that I noticed a ticking sound and everyone's suspicions were correct. a few bolts were loose by at least a 1/2 turn. I don't know how some of them can even be torqued down but I just tightened them snug. No kung fu grip on them. I still hear a ticking sound though. I didn't see any apparent cracks nor didn't notice any air or sooty areas.
