Gotts mod
Old Dec 1, 2010 | 10:58 PM
KingRanchFreak's Avatar
Gotts mod
can anyone explain to me the specific benefits of performing the gotts mod on an 08 f150 5.4 triton? Is it worth doing it?
Old Dec 1, 2010 | 11:34 PM
Barrett's Avatar
You increase the diameter of the intake that goes into the fender wall, which in turn would allow more air to enter the engine. More air=more power. Yes its worth doing it. Costs about $15, and takes about 20 minutes. Tough to beat the price for essentially a home made air intake
Old Dec 1, 2010 | 11:40 PM
Barrett's Avatar
whoops double post, sorry
Old Dec 2, 2010 | 02:44 PM
countryman777's Avatar
I am thinking of doing the gotts mod to my 2006 f150 (4.6 liter). I have read talk that its possible that it might run lean on an 04 and 05....whats the verdict on an 06 ...is it safe for me to do the mod?
Old Dec 4, 2010 | 02:29 PM
white elephant's Avatar
Oh how some things don't change!
10 years ago we were all trying this on our 97+ trucks. I was one of them. For some trucks, I would agree this is a good mod, but for many it is not.
My truck is an automatic with the biggest stock tires that came on 97-03 trucks as well as being about the heaviest for a 4.6 to push. This meant the truck needed every bit of low end torque to move the truck at highway speeds to get the best economy and prevent it from downshifting. The "snorkle" is a velocity stack that increases the volume of air going into the engine at lower RPM's helping to create more low end torque. By removing it, one is losing low end torque and gaining top end.
I initially noticed better acceleration, but after driving the same route to work daily, I noticed the truck kept downshifting more often to go up the same grades with the cruise set when it didnt shift prior to the mod. MPG's went down too.
As hard is it might seem for some to believe, the engineers aren't stupid. Every design has compromises and Ford needed and wanted to make low end power, but they didn't need it for every truck. Rather than creating more than one intake system, they settled for one that did everything well.
For those with manual trannies, other mods boosting low end, or have a lighter set-up, losing the stack can make a positive improvement. For others, not so.
Old Dec 4, 2010 | 06:33 PM
ok that makes sense. I have over sized tires and need as much low end torque as possible. I might do an exhaust system for sound, but I think i may just leave the intake the way it is for now. maybe down the road I might take the silencer out to make it sound different but in a way thats kind of pointless to. Thanks for the reply.
Old Dec 5, 2010 | 07:27 PM
Gotts2BMe's Avatar
lol it wasn't intended for low end torque it was intended for noise. Your truck runs at a constant A/F ratio of ~14.7 or close to it at part throttle. The engineers are stupid. Look at the spark plug issues
Old Dec 5, 2010 | 09:28 PM
"Your truck runs at a constant A/F ratio of ~14.7 or close to it at part throttle."
What does this have to do with what we are talking about? The CPU will always try to create an optimized fuel ratio. As long as air flow over sensors has not been disturbed by a mod, or volume of air has not exceeded the capacity of the fuel system, the engine will always see this ratio.
Old Dec 6, 2010 | 07:14 AM
lol no I was not saying I would want to do this mod for low end torque. I was saying maybe I shouldn't because I would loose some low end torque.....
and when it comes to the air to fuel ratio. I was concerned that maybe by opening the fender hole up to 3 inches could let more air past the mass air flow senser then it can register...making you run lean.
Old Dec 6, 2010 | 01:37 PM
WILDMAN442's Avatar
Take it forwhat its worth, this is my .02
I am a new member here who has caught the mod bug. I did this and immediately noticed an improvement in throttle response. the truck now cruises about 150-200 rpms lower than it did prior. I havent burned through enough gas to see the mpg improvement but looking at it right now it seems i may have improved about .5 mpg....
Like I said, that is just my experience with it, YMMV.
Justin
Old Dec 8, 2010 | 12:41 PM
Gotts2BMe's Avatar
you just proved my point. How did you get worse mileage from your modification then?
Old Dec 8, 2010 | 01:22 PM
Veteran: Army
so when you were reading did you happen to notice that the ones running lean are the 3 valve motors and all used aftrmarket hot air intakes that use a different MAF housing size????
your truck is equipped with a 2 valve motor, so as long as you reset your ecm you'l be fine
Old Dec 8, 2010 | 01:30 PM
mustangguy289's Avatar
Something to think about.... if the cpu is always adjusting the amount of fuel to achieve the 14.7 a/f ratio at all times and this is based on the amount of air that the mass air meter reads. Then as you have more air... wouldn't the computer compensate this with more fuel to achieve the same a/f ratio?
Old Dec 8, 2010 | 01:42 PM
tbear853's Avatar
white elephant, I understand increased velocity in a ventui which the stock intake tube forms, but that velocity is lost when the pipe then grows again and then that air has to pass through a filter after making it's way past all those bumpy walls of that plastic intake.
The intake tube's shape is simply to cut noise.
Old Dec 8, 2010 | 01:45 PM
Veteran: Army
you have intake and exhaust sizes mixed up
