Aftermarket Exhaust - Make it Quieter??
Old Nov 19, 2010 | 10:13 PM
kraftomatic's Avatar
Yes, I just installed a Magnaflow and it sounds great - but I'd like to make it a little quieter actually. What are some options I would have? Longer muffler? Any suggestions would be appreciated.
Thanks.
Old Nov 19, 2010 | 10:17 PM
migdaddy's Avatar
it would help us out if you told us the length of the muffler you have now. Yes, a longer muffler will make it quieter.
Old Nov 19, 2010 | 10:39 PM
I can check for exact measurements, but it's the system with the standard side exit pipe. Are there different muffler options out there I can go to?
Old Nov 19, 2010 | 10:43 PM
migdaddy's Avatar
http://www.magnaflow.com/02product/universalmuffler.asp
Old Nov 19, 2010 | 10:50 PM
Thanks. So I would then need to cut the pipe and hopefully just reclamp?
Old Nov 19, 2010 | 10:58 PM
migdaddy's Avatar
or re weld. the longer the muffler the quieter it is. http://www.magnaflow.com/02product/s...e=main&id=8926
Old Nov 20, 2010 | 12:16 AM
tbear853's Avatar
Thumbs up
Thanks.
Just do what I did and keep the muffler you already paid for in use. You can use a shorter GP, they come in many lengths. It mellows it out, the packing absorbs sound energy without adding back pressure as the core is full size straight through. Kind of like using a resonator in front of the muffler you have, and besides ..... it's cheap.
https://www.f150online.com/forums/ex...rone-help.html
Who there .... you can kill drone without a new system. I did it on my 07 5.4 F-150 Super Cab that came with a cat back Flowmaster 40 SI/DO and two welded rear exits.
We found the '07 last Augiust 2009 and instantly fell in love with it and the day we tested it out I told the wife it was too loud, she agreed. The drone was worse at certain speeds / loads. We loved the truck and where the exhaust exits and how it looked, even some of the tone, but that drone was awfull.
Well, we bought the truck. A few days later, I took it to my muffler man and he said he'ld replace it with a Series 50 SUV Flowmaster, for $175. Muffler is over $120 alone. Fair price, I almost did it.
We talked it over though ... my muffler man and I ... and since the 40 and pipes were nearly new, and as I noticed a straight piece of pipe ahead of the muffler 2.5" diameter, 28" long ... I went to auto parts store and picked up a Thrush Glasspack # 24214 , 28" long, bright red, 2.5" ID inlet and outlet, straight thru, louvered core. Picked up a saddle clamp and a short piece of 2.5" tubing. Between the tubing and glasspack, I replaced the 28" straight section with no modification to the original pipes except to drill a spot weld to reuse the rear band clamp ... so I have it if I ever want or need to slip it back in place.
I know that I said 28", but that's what I could see. Match the muffler and pipe assymbly to the pipe after you get the pipe off, it's closer to 30" total length.
In short, I cut a little off one end of the GP to allow for the wide front band clamp, inserted the piece of pipe into the muffler and cut it then so total length was same as the pipe removed, and then I cut and notched the rear end to match and once I had duplicated both ends, simply slipped it in place.
The long 2.5" glasspack with louvered core and packing removed the drone, yet the truck still has a nice tone. Costs was less than $25 ... with a can of high temp silver which I used to touch up and repaint that bright red glass pack.
If I need to do it again next year or two, I will use a stainless glasspack maybe?
Together, a Flowmaster 40 and a long Thrush or Cherrybomb glasspack make up an effective and very pleasant sounding, reasonably efficient muffling device.
I sanded and painted it aluminum high heat.
Old Nov 20, 2010 | 10:53 AM
avfrog's Avatar
A cheap glass pack does work as a great resonator when used in front of a performance muffler.
Old Nov 20, 2010 | 11:19 AM
Blue07STX's Avatar
Use a 14" or 18" quality glasspack in front of the Magnaflow. It helped out with the drone on the '05 Titan I had a few years ago.
Old Nov 22, 2010 | 08:00 AM
Where's a good place to get the glasspack guys?
Old Nov 22, 2010 | 11:22 AM
Blue07STX's Avatar
Jeg's, Summit Racing, Advance Auto Parts, O'Reilly/Kragen Auto Parts, Pep Boy's and exhaust shop.
Old Nov 22, 2010 | 02:40 PM
tbear853's Avatar
I forgot to say mine came from Advance Auto Parts.
You can find them in stainless but I don't know how much packing or how big the center is in those on line like Ebay? This one I know, the core is 2 1/2" dia as the ends.
Old Nov 23, 2010 | 07:42 AM
So is the general consensus that the glass packs works better than a longer muffler, for removing the drone sound?
Just trying to figure what path is the best ..
Old Nov 23, 2010 | 10:34 AM
Blue07STX's Avatar
What size Magnaflow, SI/SO, center/offset did you purchase? A 5x11x22" Magnaflow is as quiet as they get. It is usually more cost effective to install an 18" glasspack muffler in front of a expensive Magnaflow than it is to install a bigger Magnaflow muffler.
http://www.summitracing.com/parts/BIG-50252FLT/
Buy a can of Hi-Temp Aluminum paint, paint the glasspack and have an exhaust shop install it a few " in front of existing muffler.
http://www.summitracing.com/parts/WLK-33240/
Or cut and clamp it yourself.
Old Nov 23, 2010 | 01:16 PM
This the Magnaflow system I have Blue:
http://www.autoanything.com/exhausts....aspx?kc=ffsku
