"need" a new tip, which one though?
Old Nov 16, 2010 | 01:08 PM
hammer40's Avatar
Hello All,
I need to buy something for my truck and a new tip seems like a good cheap fix. I have the chrome package which includes a chrome tip but I'm looking for something a little bigger in diameter.
My two concerns are sound and whether or not you'll be able to see the existing pipe after installing the two below. They are both 12" long. Does that length work?
So, which one? One's a rolled tip and the other dual wall.
Thanks,
Jeff
http://www.autoanything.com/exhausts...A2501A0A0.aspx
http://www.autoanything.com/exhausts...A2503A0A0.aspx
Old Nov 16, 2010 | 02:23 PM
Stu486's Avatar
stock exhaust? aftermarket..and if so what size pipe? id say the second of the two....get 4" exit if you want it to look big but not huge..my 4 doesnt look at big as it used to, but looks very good.
Old Nov 16, 2010 | 02:58 PM
hammer40's Avatar
It's the stock exhaust, 2.5" pipe. Do you have a pic of your set up?
Thanks,
Jeff
Old Nov 16, 2010 | 03:24 PM
Stu486's Avatar
heres the only one i have...im gonna upload a couple more from other angles so you can see.
Old Nov 16, 2010 | 03:32 PM
Stu486's Avatar
sorry its not shiny...cold n wet here
Old Nov 16, 2010 | 06:07 PM
hammer40's Avatar
Thanks Stu,
I just went out and measured my chrome tip and it's 3.25" so I'll definately have to look for a bigger one than 3.5. I'm going to pull it off when it cools down and measure the pipe again. I'm starting to think it's bigger than 2.5"
Old Nov 16, 2010 | 06:23 PM
Stu486's Avatar
fairly certain stock pipes are 2.5"
Old Nov 16, 2010 | 06:38 PM
fine_style150's Avatar
ur stock piping is 2.75, or 2 3/4 i believe
Old Nov 16, 2010 | 07:33 PM
hammer40's Avatar
Fine Style, you're right,
2.75" OD. I just yanked off the tip and measured the pipe. Is that the measurement you use for sizing tips of is it I.D. which is closer to 2.5"?
Arghh.
Old Nov 16, 2010 | 07:44 PM
avfrog's Avatar
I love peoples conception on units of measurement and fractions.
Old Nov 17, 2010 | 12:05 PM
pineapple2468's Avatar
I have a single 4 inch tip infront of my rear tire. I will post pictures a little later though.
Old Nov 18, 2010 | 12:02 AM
str8t six's Avatar
^^ did you almost run over a chicken in your video?
http://www.youtube.com/watch?v=9yz8D..._order&list=UL
Old Nov 18, 2010 | 06:47 AM
WTF u want me to do im stuck with using my tape measure all day so when i layout a space i allow for 5/8 drywall not .625
Old Nov 18, 2010 | 06:49 AM
to answer the ops question i would almost think that it would make sense that the tip u look for has to be a 2 3/4" ID and the 4"s will be the OD
Old Nov 18, 2010 | 08:45 PM
avfrog's Avatar
I got a kick out of it...
