need help going with magna flow packs
Old Oct 30, 2010 | 09:58 PM
not you's Avatar
Ive been watching vids on exhaust for most of the day , the other part was giving candy to the gunes and goblins and action and super heros.Ive decided to go with magna high flow cats and magna flow packs mufflers (think thats what they are called ) Ive been watching on U tubr 4point6 punishers vids and thats the sound i like .So with that said can someone give me the part numbers for the right cats and mufflers been lookin up and cant find a part that says magna packs .Im going to be putting them on a 2010 fx4 4 door 6and a half ft bed (if needing all that info) .Are called magnapacks or magnaflow packs or something else....Also do I need a certine type of cats for my truck ,will it need a program (I hope not 4 now ) .well thats a start give me some input good or bad on this and thanks for the info on the part numbers and such .......
Old Oct 30, 2010 | 10:39 PM
4.6 Punisher's Avatar
94106 for the cats. 10416 for the Magnapacks in 2.5". Don't forget the X-pipe, 10791.
Old Oct 30, 2010 | 11:08 PM
not you's Avatar
is the xpipe needed
Old Oct 31, 2010 | 07:52 AM
enriched's Avatar
Originally Posted by not you
is the xpipe needed
Did you read through the exhaust guide sticky at the top of this section..... A lot of good info there
Old Oct 31, 2010 | 09:06 AM
No, but it helps a lot with exhaust scavenging (always good) and makes it sound a lot better.
Old Oct 31, 2010 | 09:27 AM
not you's Avatar
Thanks alot with the part numbers .......and if the x pipe makes it sound better thats what im going to do ........
Old Oct 31, 2010 | 11:00 AM
avfrog's Avatar
The sound alone is well worth the extra cash on that X pipe.
Old Oct 31, 2010 | 07:13 PM
fine_style150's Avatar
^ meaning the x-pipe is bargain for the benefit of the exhaust
Old Oct 31, 2010 | 08:01 PM
avfrog's Avatar
^ exactly
Old Nov 1, 2010 | 07:03 PM
not you's Avatar
So when I do all of this do u guys think i need a programer..... Or can I get away with out one for awhile ....What about check engine lights popping up or will it be fine ...the truck only has about 7000 ish miles on it I dont want to have any problems with it ... I do planning on going with a program but want to get a CAI before i get 1 ....thanks again with the info
Old Nov 1, 2010 | 08:35 PM
You won't need a programmer with exhaust modifications, unless you aren't going to have any cats.
Old Nov 1, 2010 | 09:12 PM
avfrog's Avatar
^ Yep
