Bad drone
Bad drone
Hey guys i have an 06 s/c with true duals, x pipe and two flowmaster mufflers
It Has a lot of drone when the converter locks up in 4th and while
crusing on the highway. Is there a different muffler yall would recommend the
would have less drone?
Wes
Wes
this is why you NEVER NEVER EVER run an X pipe and chambered mufflers
where are the tips exiting?
where are the mufflers mounted?
how cheap can your exhaust shop replace the X-pipe with an H-pipe
I like your second idea better. An H pipe will drone with that flowmaster. OP, your best bet is to change the mufflers. Borla and Magnaflow is where it is at.
H-pipes drone just as bad as X-pipes. The only thing that changes is the tone. Ditch the Slows, problem solved.
^hes got true duals bud
to do the swap and go with maggies ull need
part #14215 if its 2.25 piping or 14216 for 2.5 piping
http://www.magnaflow.com/02product/s..._universal.asp
