egr delete kit??
Old Oct 17, 2010 | 08:14 PM
stevenminix's Avatar
Question egr delete kit??
99 5.4 anyone ever tried one of these or have one? egr means exhaust gas recirculation right? if so i dont know why everyone wouldnt want one..
Old Oct 17, 2010 | 08:52 PM
Daniel09's Avatar
yes you have the correct meaning of EGR but idk why any one would waste money on one egr systems take zero power from the vehicle only made to help with emissions
Old Oct 17, 2010 | 08:57 PM
Ford12508's Avatar
EGR deletes are great for Powerstrokes, not so much for gas engines
Old Oct 18, 2010 | 02:39 AM
Just was wondering if that egr valve put nasty exhaust though my engine
Old Oct 18, 2010 | 08:04 AM
blade08gt's Avatar
yes it does put exhaust gases through your intake, but only while your cruising. it actually helps gas mileage and emissions. the egr valve closes at wide open throttle and doesnt allow exhaust to enter the intake. no point in taking it off, itll hurt your gas mileage( not significantly) turn on a check engine light and cause you to fail emissions, if you have that in your local area. plus, it will be just as fast with or without it. save your money and look for other upgrades
Old Oct 18, 2010 | 10:32 AM
4.6 Punisher's Avatar
I can see no positive for deleting the EGR unless you want to prevent build up in the intake manifold. Other than that, there are no real pro's for it.
Old Oct 18, 2010 | 09:05 PM
avfrog's Avatar
I say leave it alone.
Old Oct 19, 2010 | 03:59 AM
Looks like only alternative is supercharging it. I'd like to have cams and better heads but I'm looking for more power and more torque, low rpm kinda guy.
Old Oct 19, 2010 | 04:17 PM
blade08gt's Avatar
put a 4.10 gear in it, tuner, Gotts cold air intake, exhaust and leave it alone. unless you want to go super fast. that combo their will drag the foundation from under your house(even with a 4.6l). i have the same thing minus the 4.10 and plus a 73mm throttle body and i love it. i can drag 6500lbs up and down mountains here in East Tennessee at 70 mph with no problems. Just depends on what you want your truck for
Old Oct 19, 2010 | 04:51 PM
I have that but with 4.30 gears and it doesn't drag any foundations. I finally lost control and threw the break-in process out the window this afternoon. It still can't break traction from a dead stop by mashing the gas (might be due to the limited slip and the road). It does scoot a lot better, but I think the engine is the weak link. Maybe one of those new 5.0's can cure it.
Old Oct 19, 2010 | 07:27 PM
avfrog's Avatar
^ I forgot about the 4.30s. Was it worth the cash?
Old Oct 19, 2010 | 08:21 PM
I'm not even sure really. $1200 and it still can't break loose. Driveablilty is better though, so maybe it was. I'm still going to have to do some 0-60 times.
Old Oct 20, 2010 | 02:57 AM
jbrew's Avatar
Huh, that don't seem right. I'm running 3.55's w/LS on the 4x4 and It will break them loose -
http://picasaweb.google.com/jbrew393...40433327124514
Maybe you need to balance your exhaust ?
Old Oct 20, 2010 | 03:36 AM
jbrew's Avatar
The only reason to do this is to clean up the engine compartment. Your economy will suffer without it as that recirculation happens @ cruising speeds for the most part. Short story, the adverse effects will be Emissions and Economy.
Old Oct 20, 2010 | 05:11 AM
Raptor05121's Avatar
You obviously didnt put your 4.30 gears sticker on your truck
